Did you know? 🤔
'06 XC Fatal Fault?
2001 - 2007 XC-70
BlackBart
Has thanked: 75 times
Been thanked: 56 times
Sweden
BlackBart
Re: '06 XC Fatal Fault?
Post by BlackBart » Wed Sep 11, 2019 11:40 am
Well that makes sense for an electrical layman.
I saw a paragraph that made my smile when Matt said, "It's not just finding the needle in the haystack, but finding which haystack."
Remember when a lever (a leever) on the side of the block made the fuel pump go up and down when the crankshaft turned?
1994 850T wagon
Is it time for a 1964 122 wagon?
BlackBart
Sweden
BlackBart
Post by BlackBart » Wed Sep 11, 2019 11:56 am
Here's a link to the XeMODex CEM reprogramming. $600. They transfer the data from yours to a remanufactured and updated one.
https://xemodex.com/us/product/central- ... 455-10-22/
From their site:
COMMON COMMUNICATION FAILURES:
Water damage.
Complete loss of communication, where the CEM will not communicate with the rest of the network and the diagnostic tool.
No LIN communication with alternator (ACM).
Starter motor not working, even though start is approved by the immobilizer sequence.
Turn signals not working at all or one side turned on continuously.
Low beams, high beams or fog lights failures.
Horn not working at all.
Wipers not working at all or stuck in high speed.
Fuel pump relay not engaging.
CEM & ECU.jpeg (101.57 KiB) Viewed 20 times
1994 850T wagon
BlackBart
Sweden
BlackBart
Post by BlackBart » Sun Sep 15, 2019 9:29 pm
He says it cranks but won't start, which contradicts some of those symptoms above.
1994 850T wagon
- Pete -
Has thanked: 55 times
Been thanked: 77 times
United States of America
- Pete -
Post by - Pete - » Sun Sep 15, 2019 10:33 pm
Tell him to check the purple wire for a small section of it being "green" with corrosion. It will be within 4-5" of the plug I pictured earlier.
With ours, it would often crank but NOT start. Occasionally while running would shut off. But the crank-no-start was the most prevalent symptom. Check the easiest stuff first = this.
2001 V70XC 146k
2004 V70 AWD 141k
2004 V70R M66 144k
2004 XC70 287k
2006 XC70 155k Sold
