Did you know? 🤔
Help - ignition lock damaged / punched
zwh02
Year and Model: 1997 850
Has thanked: 0
Been thanked: 0
United States of America
zwh02
Post by zwh02 » Mon Sep 09, 2019 3:29 pm
97 850 my Volvo had it's ignition damaged by an attempted theft over night. They damaged the ignition lock in the process. The outer switch (I, II, III) part is gone/broken off, my key will fit in the remainder off the ignition but does not turn or unlock the wheel.
What do I do? I need to first just start and move the car (and turn steering wheel) but have no idea how I can do this with the damaged ignition. Help! Thank you
greg850r
Year and Model: a long list
Has thanked: 4 times
Been thanked: 9 times
greg850r
Re: Help - ignition lock damaged / punched
Post by greg850r » Mon Sep 09, 2019 8:55 pm
You'll need a long torx set to get at the column cover screws from underneath unless they broke the plastic parts off already. I'm flying blind here without pics and trying to imagine what a slide-hammer would leave you. Sounds like the pins were damaged in the attempt. It will only take one bent part to prevent the ignition from turning even if the key fits properly. Fiddle and wiggle with the key in what's left of it. You need to get the key to the on position so you can depress the pin in the little hole on top the cylinder. The rest of the lock will then come out in your hand. A replacement lock cylinder may then be inserted and should function normally. This assumes the steering column frame is not damaged. Alternatively, on the left side of the column directly opposite the ignition lock is the actual round switch held in place by 2 screws; remove them and peel it off leaving the plug attached and a short flat blade screwdriver can be inserted and turned to start the car.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4
24' 454 Challenger
07 Softail Custom
02 Sportster Custom
Parts cars not included
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 44 times
Been thanked: 154 times
bmdubya1198
Post by bmdubya1198 » Mon Sep 09, 2019 9:29 pm
Greg summed it up pretty well... pics would really help, but if they really tried to break the cylinder, you may have no option but to replace the whole ignition cylinder.
Fortunately you have an 850, and you don't have to worry about a transponder or any programming. Swing by the local junkyard and get an ignition cylinder with a key... every now and again, depending on the yard, you will be able to find one with a key.
That said, you should be able to pull that ignition switch and turn it with a screwdriver. Really easy to get to... on the back side of the ignition, remove the two screws (either T20 or T25) and pull it off, then turn the switch. That should get you going temporarily.
2000 V70R Venetian Red/Charcoal M56 Swapped 195k
2003 S60 2.4T Silver/Black 112k
2007 XC90 V8 AWD Sport Titanium Grey/Black 166k
1991 944 Turbo Dark Green/Beige 173k
1992 245 Base White/Beige 249k
2006 BMW 330i
1999 BMW 528i
2000 S70 GLT Mystic Silver/Taupe 253k
1993 944 Base Beige/Beige 221k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
Has thanked: 317 times
Been thanked: 982 times
Trinidad & Tobago
Post by abscate » Tue Sep 10, 2019 3:15 am
Only of the path to work Is perfectly straight. You need to turn the ignition key in the lock cylinder to unlock the steering, so the electrical bypass is only half the story.
Link To Volvo Glossary
zwh02
Has thanked: 0
Been thanked: 0
zwh02
Post by zwh02 » Tue Sep 10, 2019 6:51 am
Thank you for the replies. Much appreciated.
It doesn't look like they did much damage to the column, just the ignition cylinder itself got mashed up. Pictures are attached.
As I understand it and as mentioned above, I can possibly get the car started with just the electrical ignition switch. But that doesn't get me on my way since the wheel will still be locked.
When inserting the key there is not much resistance and has good amount of play, though no feeling of it actually switching (I, II, III) in the cylinder.
So If indeed I can get it into position I, then I should be able to remove the cylinder, will the wheel still be locked?
Herb Goltz
Year and Model: V70 2000
Has thanked: 1 time
Canada
Herb Goltz
Post by Herb Goltz » Tue Sep 10, 2019 7:26 am
Not sure if the '98 is similar, but on my 2000 I drilled out the peening that held in a small square cover on the bottom of the mechanical part of the switch, removed the spring and broken bits, which allowed the switch to turn again. There are good instructions on how to remove and replace the mechanical switch on this site.
bmdubya1198
bmdubya1198
Post by bmdubya1198 » Tue Sep 10, 2019 7:38 am
Right, if the car is auto he won't be able to get it out of park either, that cable is attached to the ignition.
Wow, they did a number on that thing. You should somehow be able to remove the steering long, but I'm not sure how you would go about doing that. I'm not sure exactly how it's set up.
2006 BMW 330i
1999 BMW 528i
Herb Goltz
Has thanked: 1 time
Canada
Herb Goltz
Post by Herb Goltz » Tue Sep 10, 2019 10:38 am
I seem to recall that I could remove the interlock cable once the spring was released from the bottom of the mechanical part of the switch.
