Did you know? 🤔
2005 XC90 AWD V8 oil cooler
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
5ft24
Year and Model: 2004 XC90 T6 AWD
Has thanked: 2 times
United States of America
5ft24
Post by 5ft24 » Mon Sep 09, 2019 5:38 pm
Just picked up an oil cooler from a junkyard to replace the one on mine. Looks like mine has a dent or two from hitting something. I pressure tested it at 20PSI overnight to ensure that the coolant doesn't leak internally, and now want to clean it out. I used mineral spoirits and rinsed it as much as possible, it comes out clear, but there are still small chunks of crud coming out. Used a whole can of brakleen and got quite a bit more out. I need to take it to work tomorrow and use compressed air to blow as much gunk and residual cleaner out of it as possible. Dealer gets $415.00 for a new one, this was only 25 bucks... does anyone know if the cooler is before or after the filter?
Thanks
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Has thanked: 0
Been thanked: 56 times
ggleavitt
Re: 2005 XC90 AWD V8 oil cooler
Post by ggleavitt » Tue Sep 10, 2019 10:14 pm
" Oil is led from the oil sump via a suction nozzle to the oil pump, which is located on the crankshaft. The oil pump suction function is facilitated by a purge valve that eliminates any air from the system. The oil is pumped on to the oil cooler system and then on to the oil filter. The oil is led from the filter through a cast oil duct in the intermediate section to the main bearings. The oil is distributed to the big-end bearings via drilled channels in the crankshaft... "
Before.
2005 2.5T AWD-198k
2008 V8 AWD Sport-129k
5ft24
5ft24
Post by 5ft24 » Fri Sep 13, 2019 8:42 pm
Thanks!
