Where is my coolant drain plug on XC90 ? V8
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
Pretribrapper
Year and Model: 2011 XC90 V8
Has thanked: 24 times
Post by Pretribrapper »
I have a v8 and I can't find it anywhere or any pics to tell me how to drain. I am told there is a plug on the drivers side of car but no idea where. Please help.
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Been thanked: 61 times
Re: Where is my coolant drain plug on XC90 ? V8
Post by ggleavitt »
I just did new hoses and did not see anything but the normal drain, this is what I used before pulling the lower hose. It's under the big silver colored crossmember-
2005 2.5T AWD-201k
2008 V8 AWD Sport-132k
Pretribrapper
Perfect. How does it the plug come out? Unscrew or just loosen? thx much
oragex
Year and Model: S60 2003
Has thanked: 99 times
Been thanked: 297 times
Post by oragex »
Need to undo this plug carefully - some owners tighten these too much and they are difficult to undo next time and may also break. I talk a little about this small plastic plug at 6:00 here www.youtube.com/watch?v=69ymGTqHxRw Basically, when screwing it back in place, you can just tighten it by hand until it stops rotating - it will stay in place and seal properly (same idea as the oil filter cup, for example)
Pretribrapper
Awesome. One last question for now. Reason I ask is because I have to change my starter and there is a little metal piece attached to a hose right a move the starter that I need to remove to get the starter out. If I disconnect this piece without draining some coolant do you know if coolant will leak from here? I would rather not have to drain...
Pretribrapper
Right *above* the starter. Typo above...
ggleavitt
Post by ggleavitt »
Couple coolant filled hoses run higher than that location (heater hose as example, just below your drawing). I think you'll need to drain some if you don't want to make a mess.
2005 2.5T AWD-201k
MolehSpoon
Year and Model: 2018
Post by MolehSpoon »
Above the Starter.
