Did you know? 🤔
13 S60 T5 AWD Front suspension bearing
Help, Advice, Owners' Discussion and DIY Tutorials for the groundbreaking new Volvo S60 2011+, V60 and XC60.
cdretc
Year and Model: 13 S60 T5 AWD
Has thanked: 0
Been thanked: 0
Canada
cdretc
Post by cdretc » Tue Sep 10, 2019 6:18 am
My front suspension bearing is gone. Can I just replace that or does the spring seat also need replacement? Is there an upgrade or should I just use the original Volvo one? Or are OEMs good enough? Thanks
coldax
Year and Model:
Has thanked: 0
Been thanked: 0
coldax
Re: 13 S60 T5 AWD Front suspension bearing
Post by coldax » Fri Sep 13, 2019 12:57 pm
I actually doing a full suspension replacement on my 2012 T6 as I type this, front and rear. I am replacing everything but the spring i front. It just makes sense because the job is a PITA, having to compress the spring. Might as well pit all new in while you have it apart. My car is at 80K and the strut is shot, and the bearing is noisy and grinds. Check out IPD they offer a few aftermarket choices, I think they are all about the same.
2012 XC60 T6
2012 S60 T6
2007 S40 2.4
Gone but not forgotten:
2009 C30 R Design
2010 V50 2.4
2000 V70 SE
2000 S70 SE
cdretc
Has thanked: 0
Been thanked: 0
Canada
cdretc
Post by cdretc » Fri Sep 13, 2019 6:54 pm
It makes the job twice as expensive. The bearing is rubber but the seat is metal, so I don't know if it can wear out. Maybe your spring tool is not very good, I don't find it difficult to compress at all, but I also have air tools, so maybe that's the difference. Thanks for your feedback though. I hope your job went well.
coldax
Year and Model:
Has thanked: 0
Been thanked: 0
coldax
Post by coldax » Sat Sep 14, 2019 8:27 am
I guess if the seat is not bent or corroded it is OK to reuse. Personally I would not want to have to take it out again. Going with Volvo part will be expensive but like I said there are aftermarket options much cheaper, some places offer the bearing and seat as a kit.
My spring tool is too long - the threaded rod hits the flange before full compression. This year I just bought a Milwaukee 1/2 cordless impact wrench. Probably the best tool purchase I have ever made.
2012 XC60 T6
2012 S60 T6
2007 S40 2.4
2009 C30 R Design
2010 V50 2.4
2000 V70 SE
2000 S70 SE
