Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
Coolant water pipe gasket
- Year and Model: 2011 XC90 V8
- Has thanked: 20 times
- Been thanked: 0
Changed my starter and noticed that I have a small coolant leak by the pipe that connects to the motor. I ordered a new gasket but noticed a rubber o ring about an 1.5" rubberpiece under my car after I put car back together and I wondered if there was actually supposed to be a rubber gasket used with the main gasket. See pics. Basically I just want to know is this the only gasket I use for this coolant pipe or was a rubber o ring also supposed to go on this gasket??
- ggleavitt
- Year and Model: XC90 05-2.5T, 08-V8S
- Has thanked: 0
- Been thanked: 53 times
Re: Coolant water pipe gasket
Just the gasket, PN 30720318. Bolts are M8, torque per VIDA is 24Nm (18 ft lb).
Post a photo of the o-ring if you get the chance, maybe someone can spot where it goes (if indeed it's for your vehicle).
- These users thanked the author ggleavitt for the post:
- Pretribrapper
2005 2.5T AWD-198k
2008 V8 AWD Sport-127k
- Been thanked: 0
- Been thanked: 0
Here is the pic of the o ring I found in my drip catcher under the vehicle. Trying to figure out where its from. Found after I replaced the starter originally
98 S70-Advice for Gasket & Filler Pipe replacement
by rugbygrrl_15 » Fri Jul 12, 2019 12:35 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 12 Replies
- 224 Views
Last post by erikv11
Wed Aug 07, 2019 9:55 am
Cut "Coolant Pipe" into 5 Pieces with Hacksaw
by Love2FlyJets » Wed Nov 23, 2016 2:09 pm » in 240, 740, 760, 780, Bertone, 940, 960, V90, S90 - 9 Replies
- 1594 Views
Last post by Love2FlyJets
Thu Sep 14, 2017 11:26 pm
1998 v70 GLT metal coolant pipe help!
by howierodgers » Tue May 09, 2017 1:41 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 5 Replies
- 704 Views
Last post by howierodgers
Wed May 10, 2017 9:35 am
Turbo Coolant pipe 2001 v70 xc
by medicmatson » Thu Dec 21, 2017 4:09 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 1 Replies
- 219 Views
Thu Dec 21, 2017 6:57 pm
