Did you know? 🤔
Brake problem
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
jajak900900
Year and Model: XC90 2006
Has thanked: 0
Been thanked: 0
Finland
jajak900900
Brake problem
Post by jajak900900 » Wed Sep 11, 2019 9:01 am
XC90 2006 problem pulling the brakes to the right. The car has been replaced with front brake discs, pads, lower link arms, four-wheel alignment, rear brake pins. The car still pulls right sharply when I brake. What next? The brake test claims the brakes are equal. There are no defects in any joints. :?:
volvooh
Year and Model: '98 S70, '05&'08 V70
Has thanked: 0
United States of America
volvooh
Re: Brake problem
Post by volvooh » Thu Sep 19, 2019 6:26 am
I am going to be addressing a similar issue, so I am curious to hear what you find out. My first move was to replace brake pads and do a bleed. My next move is the front lower control arms and ball joints and an alignment.
My guess is you are getting "flex" in your suspension. I have read where aftermarket parts can have bushings that are not necessarily up to snuff as braking on these vehicles seem to put a lot of stress on suspension components.
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Has thanked: 0
Been thanked: 54 times
ggleavitt
Re: Brake problem
Post by ggleavitt » Thu Sep 19, 2019 9:20 am
Another post- https://forums.swedespeed.com/showthrea ... -2006-2-5T , was this resolved ?
2005 2.5T AWD-198k
2008 V8 AWD Sport-127k
jajak900900
Has thanked: 0
Been thanked: 0
Finland
jajak900900
Re: Brake problem
Post by jajak900900 » Thu Sep 19, 2019 9:55 am
Bug has been found. Front arm frame bushing bolt hole is too big, arm can move if bolt is not too tight. Can a bushing be fitted with something to reduce the hole? Apparently, the arm bushing is unsuitable for this model. The stem does match the oem number.
The fault was not in the brakes.
Masscomguru
Year and Model: 2008 XC90
Has thanked: 0
Been thanked: 10 times
Masscomguru
Re: Brake problem
Post by Masscomguru » Thu Sep 19, 2019 11:53 am
Sounds like they reused the bolts. A new bolt from volvo will fix your issues. The collar size was updated. Also, these bolts are torque to yield so they shouldn't be reused.
jajak900900
Has thanked: 0
Been thanked: 0
Finland
jajak900900
Re: Brake problem
Post by jajak900900 » Thu Sep 19, 2019 12:26 pm
What is that rubber bolt like? You can't put a thicker bolt on that frame. Bolt number 14 in picture.
