Support MVS at NO COST To You!
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
Let's make a small effort that may help Matthew's Volvo Site a LOT!
I go to Amazon several times a day and spend WAY too much money there.
I just changed my Amazon BOOKMARK to this:
https://www.amazon.com/?tag=matthewsvolvo3-20
From now on, MVS will get some money when I go to Amazon!
Check out other ways to help at this page:
https://www.matthewsvolvosite.com/mvs-sponsors-partners
All U.S. market models.
All running and on the road.
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
Thanks for the reminder on this.
I do have a question for Matthew. Do you get a report on how many purchases were made ?? I never quite trust this process as there is no traceability between the first click over and when I purchase something. Meaning Amazon doesn't show that a % of my purchase went to help Matthew's site. I never feel confident that any purchase I made really contributes to the site in question. I wish I knew how this all worked and how the recipient know they are getting what they deserve .
Regardless, I did update my bookmark for amazon. Now I have to remember it's there instead of just typing amazon into the address bar.
-A
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2865 times
Been thanked: 1332 times
Post by matthew1 »
Thanks Amblerman and Eddystone. Amblerman, you're correct, there is no transparency in this process. I think Amazon likes it this way (or else they would have changed it obviously).
They don't want to help this along because that % comes off the top of their take. They take the haircut.
I do get a report however. This report offers no identifying info as you'd expect. Essentially it shows product, # of orders it got, and the product's price. Here are products from that report for the last 30 days:
iCarsoft Auto Diagnostic Scanner V200 V2.0 for VOLVO/SAAB with ABS Airbag Scan,Oil Service Reset EPB BMS ect
Mobil 1 55221 3309 Automatic Transmission Fluid - 1 Quart (Pack of 12)
Traxxas 2972 EZ-Peak Plus 100 Watt NiMH/LiPo Dual Charger with iD System
Denso 234-9040 Air Fuel Ratio Sensor
Flat Electronic Wall Safe .83 CF for Large Jewelry Security-Paragon Lock & Safe
AUTOPHIX ES610 Obd2 Scanner Code Reader Auto Diagnostic Tool for Volvo Engine ABS SRS Airbag Transmission Systems
BETOOLL Pro Fuel Injection Pressure Tester Kit Gauge 0-140 PSI
Edgewater Parts W10503278 Brand New Control Board Compatible With Whirlpool, Maytag Refrigerator
Columbia Big Girls' Katelyn Crest Jacket, Black, Large
EWK Camshaft Crankshaft Alignment Timing Locking Tool for Volvo 850 S40 S60 9995452
Volvo 8692071, Spark Plug
NEW W10503278 Refrigerator Control Jazz Board for Whirlpool Maytag WPW10503278, 12784415, 12868513, AP6022400, PS11755733, W10165748-1 YEAR WARRANTY
W10503278 WPW10503278 Refrigerator Control Jazz Board for Whirlpool Maytag Kenmore # 12784415 12002339 12002445 12002449 12002508 12002509 12002567 AP
MAF Mass Air Flow Meter Sensor fit for Volvo 1995-1997 850/1998 C70/ 1998 S70/ 1998 V70 2.3L L5
Bosch Automotive 0261230238 Pressure/Temperature Sensor
Wireless Endoscope,DEPSTECH Upgrade 5.0MP HD WiFi Borescope, 16 inch Focal Distance, Semi-Rigid Snake Inspection Camera with 2600 mAh Battery for iOS
Castrol 03057 GTX MAGNATEC 5W-30 Full Synthetic Motor Oil, 5 Quart
Clear Choice Sediment Filter Cartridge 10in X 4.50in Replacement for Pentek 155101-43 R30-BB, GE FXHSC, Whirlpool WHKF-WHPLBB, American Plumber W30PEH
MAHLE Original LAK 54 Cabin Air Filter
Pioneer ADTVA133 2 Din Installation Kit
Vive Comb Rechargeable Wireless Bluetooth Mouse Compatible with MacBook, Laptop, Windows Android Mac OS Quiet Clicking Mouse with Bluetooth, Type C an
Fuel Line Check Valve for 5/16" Lines
Genuine Volvo 30672719, Glove Box Compartment Latch (XC90)
NewYall Engine Radiator Cooling Fan Control Relay Control Module
Bapmic 30748811 Front Right Engine Motor Mount for Volvo C70 S60 S80 V70 XC70 XC90
Upgrade Mini Bark Control Device, Outdoor Anti Barking Ultrasonic Dog Bark Control Sonic Bark Deterrents Silencer Stop Barking Bark Stop Repeller, No
ATP AT-205 Re-Seal Stops Leaks, 8 Ounce Bottle
MAHLE Original LX 700 Air Filter
Cherokee Men's Big and Tall Originals Cargo Scrubs Pant, Pewter, Medium
Cherokee Men's Big and Tall Originals Cargo Scrubs Pant, Pewter, Large
Barrina LED T5 Integrated Single Fixture, 4FT, 2200lm, 6500K (Super Bright White), 20W, Utility Shop Light, Ceiling and Under Cabinet Light, Corded El
Beck Arnley 101-7344 Stabilizer End Link
Amazon eGift Card - Amazon Logo
pcs/lot Hantek HT201 20:1 Passive Attenuator For Pico, 300v Max
JINSHI Men's 2 Pack Lightweight Pajama Short Comfy Plaid Stretch Sleep Lounge Pajama Short with Pockets Medium
Heavy Duty 7-Piece Oil Filter Cap Wrench Tool Kit Can Last for Ever Includes 24mm,27mm,29mm,30mm,32mm,36mm,38mm Socket Set Compatible with Mercedes Be
Aintier Air Sensor Mass Air Flow Sensor MAF Replacement Fit for 2003-2004 Volvo C70 S60 S80 V70 XC90 2005-2007 Volvo V50 S40 C70 S80 2004 Volvo S60 V7
MAHLE TX 202 90D THERMOSTAT,INSERT
Autel MS300 OBD2 Scanner Code Reader, Turn Off Check Engine Light, Read & Erase Fault Codes, Check Emission Monitor Status CAN Diagnostic Scan Tool
Cherokee Men's Originals Cargo Scrubs Pant, Pewter, Large
EXP1250 12V 5Ah Home Alarm Battery with F1 Terminals // Chamberlain / LiftMaster / Craftsman 4228 Replacement Battery for Battery Backup Equipped Gara
SanDisk 128GB Ultra Fit USB 3.1 Flash Drive - SDCZ430-128G-G46
MulWark 20pc 1/4 Ultra Low Profile Mini Ratchet Wrench Close Quarters Screwdriver Set with High Torque - Right Angle EDC Tool with 90 Degree Mini Offs
Hot Surface Oven Igniter, Capilary 12in L
Lumenon LED Headlight Bulbs Conversion Kit 180W 180000LM 6000K Cool White 2 Yr Warranty (H7)
Motivx Tools Volvo Oil Filter Wrench for 86mm Cartridge Style Filter Housing Caps
Oetiker 14100396 Pincer, Straight Jaw
Duck Brand 240200 Double-Sided Duct Tape, 1.4-Inch by 12-Yards, Single Roll
Genuine Brother 1/2" (12mm) Black on White TZe P-touch Tape for Brother PT-2100, PT2100 Label Maker with FREE TZe Tape Guide Included
AmazonBasics Lightning to USB A Cable, MFi Certified iPhone Charger, White, 6 Foot, 2 Pack
Vgate OBD2 Scanner iCar2 Bluetooth Diagnostic Tool Support All OBD Protocals
Large Pencil Case Organization Storage - Big Capacity Storage Pen Bag Pouch Holder Maker Stationery Organizer with Durable Zippers for Middle High Sch
Bamoer Auto Windshield Repair Tool, Car Windshield Repair Kit with Windshield Repair Resin for Windshield Chip Repair, Windshield Crack Repair and Gla
The Red Baron
Aces High
Warmstor 21 Pieces Premium Opening Pry Tool Screwdriver Set Repair Kit for iPhone XS Max/XS/XR/X/8/8 Plus/7/7 Plus/6S/6/6 Plus/5/5C/5S/4/4S, iPad Pro/
Esdabem Repair Tool Kit for iPhone 7 - Complete Premium Opening Pry Tool Kits with Titanium Alloy Screwdriver Set for iPhone X/8/8 Plus,7plus, 6Plus /
Floureon 38-piece Precision Screwdriver Set Repair Tool Kit for iPad,iPhone,PC,Watch,Samsung and Other Smartphone Tablet Computer
Shoe GOO Shoe Repair Adhesive, Clear
Pull Chain Extension KINDPMA 16 Feet Metal Brushed Nickel Sliver Beaded Ball Chain with 20 PCS Connectors for Ceiling Fan Light Chain
Stant 45379 SuperStat Thermostat - 195 Degrees Fahrenheit
HELLA 7507TB Natural Amber-21W Standard Miniature 7507 Bulbs, 12V, 21W, 2 Pack
SEALIGHT H4/HB2/9003 LED CAN-BUS Warning Error Free Decoder Canceller Capacitor Anti-flicker Resistor harness Hi/Lo Beam Headlight Systems
Keychain Ring, Lucky Goddness 15pcs Non-Welded 1 Inch O Ring- Perfect for Key Clips, Dog Collar, Purse Hardware Suplies, DIY Project, Handmade Crafts
GearWrench 82517 3/8" Drive Long Torx Bit Socket T40
Gorilla Tough & Clear Double Sided Mounting Tape, 1 Inch x 60 Inches, Clear
-Pcs - Panasonic CR1620 (Prepackaging) 3v Lithium Coin Cell Battery
Chengstore 2pcs 1/4" Brass NPT MPT Tank Valve, Tire Tyre Air Compressor Tank Fill Valve
Mann-Filter HU 819 X Metal-Free oil filter
(10) M5-0.80 x 8mm - Stainless Steel Socket Set Screws w Cup Point A2-70/18-8 DIN 916 - MonsterBolts (10, M5 x 8mm)
Ball Chain #6 Lamp/Fan Pull Loop Connectors-SILVER (10 pieces)
The Blue Max
Beck Arnley 039-0019 Thermostat Gasket
HELLA 2825TB Standard-5W Standard Miniature Bulbs, 2 Pack
Pack Biotene Oral Balance Dry Mouth Moisturizing Gel 1.5 oz soothe oral tissues long
PRO ART SH1956-BKPNK-3XSPro Art 36-Inch by 5-Yards Tracing Vellum Paper Roll
Trademark Poker Card Shuffler
PACK 0F 5 - Workman TP-2 CB Radio Polarized Quick Disconnect 2 pin 12" 16 Gauge
Muscle Rack UR184872-R 5-Shelf Steel Shelving Unit, 48" Width x 72" Height x 18" Length, Red
Skechers Men's Oak Canyon Oxford, Chocolate/Black, 9 M US
THE GIFT FOR LIFE Advanced Joint Pain Relief, Anti - Aging Formula
Skechers Men's Oak Canyon Oxford, Chocolate/Black, 9 4E US
Evolve Protein Shake, Classic Chocolate, 20g Protein, 11 Fl Oz, Pack of 12
Vet One 600107 VetraSeb P Pet Shampoo, 16 oz
Feosol Ferrous Sulfate Iron, 120 Count, High Potency Iron Supplement
CloSYS Fluoride Toothpaste, 7 Ounce, Gentle Mint, Whitening, Enamel Protection, Sulfate Free
Spring Valley - Vitamin D-3 1000 IU, 450 Softgels
Ergodyne 19112 Glove Grabber, Black, (Pack of 6)
Equalizer 2
Live In '67
there is no Other
Episode 4
Evercare Mega Large Surface Roller Refill 50 Sheets (6 Pack)
Foamily 12" x 20" Premium Hypoallergenic Lumbar Stuffer Pillow Insert Sham Square Form Polyester, Standard/White
Zero Odor Multi-Purpose Household Odor Eliminator, Trigger Spray, 16-ounces
CaliTime Pack of 2 Throw Pillow Covers Cases for Couch Sofa Home Decoration Vintage Damask Floral Shining & Dull Contrast 18 X 18 Inches Gold
BRAWARM Pack of 2 Cozy Bolster Pillow Covers Cases for Couch Sofa Bed Solid Faux Leather Soft Luxury Cushion Covers Both Sides Home Decoration 12 X 20
Duracell - CopperTop 9V Alkaline Batteries - long lasting, all-purpose 9 Volt battery for household and business - 4 count
Nabob Wipers Auto-Mechanic Shop Towels, Shop Rags 100% Cotton Commercial Grade Perfect for Your Garage, Auto Body Shop & Bar Mop (12x12) inches, 25 Pa
Foamily Premium Hypoallergenic Stuffer Pillow Insert Sham Square Form Polyester, 18" x 18" White
Lemon Squeezer, New Premium Quality Metal Lime Squeezer Manual Citrus Press Juicer 2-in-1 with Long Handle Spoon By Best shop 2016
AUTOLOVER Wireless Backup Camera, HD 720p Backup Camera for car, Vehicles WiFi Backup Camera with Night Vision / IP67 Waterproof for iPhone, iPad or A
Amazon eGift Card
Unicorn Dabbing Motivational I'm Doing My Best T-Shirt
Large Paper Towel Holder Wall Mount Under Cabinet Kitchen Hanging Toilet Paper Towel Holder Gifts For Women & Men
Obenauf's Leather Oil Condition Restore Dry Leather (16oz With Applicator)
Chemical Guys TVD11504 Trim Clean Wax and Oil Remover (4 oz)
Also -> Amazon link
amblerman
Post by amblerman »
Ok great. I figured they couldn't send you personal info but it's interesting you're seeing actual product names as opposed to "Hey 5 people bought 5 things". I'll make sure I buy through the link.
