Did you know? 🤔
95 850 turbo (non-R) crank no run
echosierra
Year and Model: 1995 855T
Has thanked: 1 time
Been thanked: 0
United States of America
echosierra
Re: 95 850 turbo (non-R) crank no run
Post by echosierra » Wed Sep 18, 2019 8:20 am
maybe i need to also do what this guy did at the end:
viewtopic.php?t=25633
1995 855 Turbo
Has thanked: 103 times
Been thanked: 311 times
Post by erikv11 » Wed Sep 18, 2019 12:08 pm
It's really OK to pull the ECU, even if it's tight. I've done it many, many times.
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
echosierra
Has thanked: 1 time
Been thanked: 0
echosierra
Post by echosierra » Thu Sep 19, 2019 8:35 am
another small update. the main relay plug on the radiator...i see now that the connector is crap and corroded. the plastics holding the female terminals are degraded and don't hold the terminals well anymore, so they slip down and lose the connection to the relay. i pushed the terminals up and plugged each of them into the relay, then slid the connector housing over the terminals and secured it to the relay. still no run.
based on others' experience, i feel like i'm chasing a bad ground somewhere that is keeping the injectors from firing or closing the circuit so they fire. i haveall the elements of running (good compression, good fuel pressure, good spark, 12v power to the injectors) and it runs on starter fluid for a few seconds.
great...I hate chasing bad grounds
1995 855 Turbo
echosierra
Has thanked: 1 time
Been thanked: 0
echosierra
Post by echosierra » Thu Sep 19, 2019 10:18 am
so to prepare me for chasing elec problems...do you guys know where all the grounds are in this car? there's one on the rear of head, one below the battery...where else should i be looking to clean the grounds up?
1995 855 Turbo
Post by erikv11 » Thu Sep 19, 2019 1:39 pm
two on the firewall side, one near each end of the exhaust cam.
'96 855 NA, 145k
'06 S60 R, 167k
echosierra
Has thanked: 1 time
Been thanked: 0
echosierra
Post by echosierra » Thu Oct 10, 2019 9:01 pm
Ok its been a while and I have news
After swapping the crank sensor with a new one, the injectors got pulse, but still werent squirting. Keep in mind the first thing I did when i bought the car was to send injectors off to be rebuilt...i did this more for my peace of mind than anything. This ended up being a mistake b/c all 5 injectors were not squirting even with a pulse.
After confirming they got pulse (and they didnt have pulse in prev diagnosis due to a bad crank sensor), i swapped the parts car injectors and she fired right up!
Im angry that the shop that supposedly rebuilt the injectors did a crap job!
So if your car runs ok, chances are that you wont need a injector rebuild
But she’s up and running now! Not i need to dig into low boost
Appreciate all your help here!!
1995 855 Turbo
Post by erikv11 » Thu Oct 10, 2019 10:18 pm
Could you tell us who rebuilt the injectors?
'96 855 NA, 145k
'06 S60 R, 167k
RickHaleParker
Has thanked: 3 times
Been thanked: 575 times
RickHaleParker
Post by RickHaleParker » Thu Oct 10, 2019 11:50 pm
Post pictures of the rebuilt the injectors, business end views.
Measure the resistance of each injector and post the numbers.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, B8444S TF80 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger. V8 conversion in progress.
echosierra
Has thanked: 1 time
Been thanked: 0
echosierra
Post by echosierra » Fri Oct 11, 2019 4:31 am
All 5 measured 14.9 ohm
Yes its weird to say that the rebuilds are bad, esp when the shop gave me a writeup saying that the spray pattern was improved, etc.
I didnt want to list the name of the shop yet....maybe theres some protective cap im missing or totally not seeing w/the rebuilt ones. Am I the idiot here?
If im not stupid, and the rebuilds are truly bad, then ill list the name of the shop.
1995 855 Turbo
Post by erikv11 » Fri Oct 11, 2019 8:47 am
Probably a distraction but are those yellow (wrong, NA injectors) or orange or red (correct injectors)? Presumably yellows would still fire, I don't know of anyone ever trying them in an HPT engine, but just curious.
'96 855 NA, 145k
'06 S60 R, 167k
