Did you know? 🤔
how is camber adjusted in p3 chassis? s80
Help, Advice, Owners' Discussion and DIY Tutorials on the third generation Volvo V70 wagon and XC70 crossover, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
twerner
Year and Model: 2007 s80 3.2
Has thanked: 0
Been thanked: 0
United States of America
twerner
Post by twerner » Thu Sep 19, 2019 11:10 am
Any ideas on how to adjust camber with these cars? The strut slides in a bore that is in the spindle, so no offset bolts there. lowers are fixed. Wondering how the adjustment is made?
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 36 times
Been thanked: 76 times
MoVolvos
Re: how is camber adjusted in p3 chassis? s80
Post by MoVolvos » Mon Sep 30, 2019 9:43 pm
By looking at the link below are no provisions for any other alignment adjustment except Toe. In the world of alignments it's "Set The Toe & Let It Go".
https://www.volvopartswebstore.com/show ... evel=24651
However, there is a slight play in the stock lock nuts to the strut assembly. You can make a minor adjustment to the camber. If you need more than that there is a usually a problem somewhere.
Below is a set of Camber Adjustment Bolt to help cars with slightly more Camber issues or minor problematic suspensions. It's suitable for a 2007 S80 3.2.
https://www.amazon.com/Specialty-Produc ... +Volvo+S80
FINALLY: The SAI angle is the one to look at during an alignment as it will indicate whether your have a bent suspension, usually the strut assembly.
https://www.freeasestudyguides.com/included-angle.html
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
twerner
Has thanked: 0
Been thanked: 0
twerner
Post by twerner » Fri Oct 04, 2019 11:28 am
Thanks,, yes I noticed the play in the strut tower, might be able to get what I need with that.
Thanks
