I now have a Fuel Pressure Gauge tester. All the instructions I found are on a running engine. How can I test if the engine turns but don't start? That is for a 2001 V70XC without a Fuel Pressure Sensor on the fuel rail but a valve.
Thanks
How to test fuel pressure without engine running
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Should be the same. The fuel pump runs as soon as you turn the key regardless of whether the engine is turning, igniting or not. Not forever but long enough for normal pressure if the car has been parked long if everything is ok.
Oka
Oh, OK, I will give that a try. Thank you!Rattnalle wrote: 22 Sep 2019, 13:58 Should be the same. The fuel pump runs as soon as you turn the key regardless of whether the engine is turning, igniting or not. Not forever but long enough for normal pressure if the car has been parked long if everything is ok.
- 16142 Views
Last post by Richard99
- 4194 Views
Last post by rred
- 12 Replies
- 3398 Views
Last post by MrAl
- 7960 Views
Last post by adrian22
- 11 Replies
- 2990 Views
Last post by oldironsights
