I am having an issue with the door latch not locking (grabbing) onto the catch in the door jamb. Door will just swing open/close. The door locks work fine with the key fob and buttons so I don't think that is the issue. Perhaps something has come undone in the mechanism? I moved the latch to the closed position and pulled the door handle, nothing happened and I found it easy to push it back to the open position.
Any suggestions? And, If I need to take it to be repaired would you recommend a mechanical repair shop or body shop?
Cheers!
2012 S60 Rear Door Lock Fail
Did you manage to fix it?
Found that it's a safety recall in 2020.
https://www.autoblog.com/2019/12/17/vol ... r-latches/
https://recalls-us.volvocars.biz/pdf/R89978.pdf
- 2034 Views
Last post by Dmck
- 2345 Views
Last post by jimmy57
- 1442 Views
Last post by joevar
- 3752 Views
Last post by BeeEl
- 7427 Views
Last post by precopster
