Did you know? 🤔
Unlock Truck From Back Seat? Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 26 times
Been thanked: 49 times
United States of America
MoVolvos
Post by MoVolvos » Tue Sep 24, 2019 10:49 am
The key no longer works on the trunk lock. The spring for the flap door to the lock fell off and is blocking the key from entering.
The alarm module under the passenger wheel well needs a battery so the remote does not work at this time.
Any advise on getting into the trunk from the backseat so I can pull the cord? Thanks.
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
Rattnalle
Has thanked: 18 times
Been thanked: 121 times
Sweden
Rattnalle
Re: Unlock Truck From Back Seat?
Post by Rattnalle » Tue Sep 24, 2019 11:49 am
On the S80 the lock actuator is a microswitch and the lock should unlock when using the key in the door. You're saying it doesn't? The key hole in the back is mostly for when there's no power so the switch doesn't work.
MoVolvos
MoVolvos
Post by MoVolvos » Tue Sep 24, 2019 1:11 pm
When the battery died in the Alarm Module in the passenger fender well I lost the use of the trunk remote and button at the trunk. The key hole is also broken as the small flap door spring broke so the face just spins and can't get the key in.
Don't have time to remove the Alarm Module Battery so would like get into the trunk from the back seat and tie a twine to the Yellow Emergency Pull Clip and open from the back seat for now. Good thing I didn't go grocery shopping or it would be gross siree by now.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
Rattnalle
Sweden
Rattnalle
Post by Rattnalle » Tue Sep 24, 2019 1:25 pm
Then I'd say your best bet is to send a child through the ski hole in the rear seat to fold the seat down from inside the trunk. Unless you've got very long arms and can reach yourself.
MoVolvos
MoVolvos
Post by MoVolvos » Wed Sep 25, 2019 3:51 pm
How do you get that open from the back seat? The armrest comes down but the plastic does not move.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
Rattnalle
Sweden
Rattnalle
Post by Rattnalle » Wed Sep 25, 2019 11:06 pm
I used to be able to pry mine open by hand on my 01. It's a small tab up top then it folds down on top of the arm rest.
These users thanked the author Rattnalle for the post:
MoVolvos
MoVolvos
MoVolvos
Post by MoVolvos » Mon Sep 30, 2019 8:37 pm
Had a moment so I managed to pull it down today. I think a credit card inserted at the top of the tab would do it easily. Will update after I open it from the ski hole. Thank you.
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
MoVolvos
MoVolvos
Re: Unlock Truck From Back Seat?  Topic is solved
Post by MoVolvos » Sun Oct 20, 2019 8:49 pm
Used a long thin wooden rod with an eye hook screwed into the tip to pulled the yellowish plastic tab and opened the trunk. Next removed the clips of the trunk lid interior cover and then the 2 screws for the trunk lock.
As I suspected the spring for the flip cover where you insert the key popped off. Son saw it come off earlier and kept it. The flip cover had dropped into the key hole and jammed into the lock. Remove it and now it works. Didn't bother trying to put the spring or the flip cover back just in case it jams again. Will see if debris gets in with the next big rain.
Thanks Rattnalle!
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
Free shipping all USA - Experts in Brakes
