2001 XC Car Will Not Start Anymore, intermittent crank, no fire
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
Few months back, when I step harder on the gas to overtake a car, I tend to, sometimes, have a small hesitation.
The issue started getting more noticeable. Few weeks ago, it just stalled. With the ignition, the engine will turn but
won't start. Battery is ruled out.
FUEL PRESSURE READING
I connected a gauge to the rail at the valve and turned the engine (since the car would not start).
Here's my reading. What would that mean, though it's above the 40psi requirement.
I am trying to troubleshoot the car not starting anymore.
Months back, it hesitates when applying more acceleration, then, it starts stalling, then it gave up.
https://flic.kr/p/2hjt9eY
ECM TESTING
Plugged in the VIDA and got this (Video).
I had to edit the video to increase the audio volume level.
By the way, the Turbo Valve has a thumping sound but not loud enough to hear.
Hope I did good enough here.
Thanks again everyone for helping me here.
https://youtu.be/MnWURGSzmvQ
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
Check/replace the crankshaft sensor. If this gives a faulty reading, the ECU will halt the car as a safety measure (prevent fire)
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
Oka
Post by Oka »
ndphotonl wrote: 25 Sep 2019, 09:45 Check/replace the crankshaft sensor. If this gives a faulty reading, the ECU will halt the car as a safety measure (prevent fire)
Interesting. Would a bad crankshaft sensor prevent the car from starting?
Thanks.
ndphotonl
Post by ndphotonl »
Yes it will, I believe the fuel pump is shut down (as that safety measure)
FlickR images
Oka
Post by Oka »
ndphotonl wrote: 02 Oct 2019, 13:19 Yes it will, I believe the fuel pump is shut down (as that safety measure)
Mmmm, very logical point. That never crossed my mind. Googled and found a sensor can be tested with a multimeter, would the testing also apply for the 2001 X/C?
Thank you.
ndphotonl
Post by ndphotonl »
I have no idea to be honest (I'm more of a mechanical guy as opposed to electrical). I wouldn't even bother and replace it straightaway, but that's me personally :D
FlickR images
Has thanked: 1609 times
Been thanked: 4064 times
If you don’t want to replace Lots of expensive parts, find the no-start thread and start 😁 there withdiagnosing the fault.
Oka
Post by Oka »
All is well now. The culprit were the two outside temperature sensors that prevented the remote starter from starting the car as low as at 45F.
Oka
Post by Oka »
abscate wrote: 08 Oct 2019, 05:35 If you don’t want to replace Lots of expensive parts, find the no-start thread and start 😁 there withdiagnosing the fault.
I tried the remote fob 5-time presses but don't know if that made it start.
Now the car will start. I am going to post a new message of the current situation now still under this original title.
"Car Will Not Start Anymore"
Oka
Post by Oka »
For the Immobilizer See Manual, two days ago and yesterday, I did one of the tricks to possibly clear the Immobilizer See Manual error. Press the fob OPEN and CLOSE five times and then start the car. Then the car started. Don't know if that was what made it start.
This morning at home, it started with the remote with the Check Engine light on. On my way to work, went to Lowes. From Lowes, the Check Engine light went off then two minutes later, at a stop light, I noticed the little hesitation and a little dimming of the dash light. When I restart the car, it surges a little bit from 750RPM to about 1,200RPM while the light dims a little.
Mass Air Flow issue? Alternator issue?
Please help!
