IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
2001 XC Car Will Not Start Anymore, intermittent crank, no fire
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
highmiles
Year and Model: 2001 S60 T5
Has thanked: 7 times
Been thanked: 3 times
United States of America
highmiles
Re: Car Will Not Start Anymore
Post by highmiles » Thu Nov 21, 2019 2:36 pm
The audio is helpful, it certainly "wants" to start. The bad smell makes me think that it the car is dumping gas into the system? Would a split intake tube leaking unmetered air into the system cause this?
I agree that the battery is turning the car over just fine.
I had an e30 BMW once that had a mystery starting issue that turned out to be a ground cable. The cable was present and looked fine but once I gave it a good tug it just broke off. The Volvo seems to have more redundancy in grounds so I don't know if this would be an issue.
None of the codes from earlier really jump out. Maybe reset all then see what comes back?
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 254 times
Been thanked: 811 times
Trinidad & Tobago
Post by abscate » Thu Nov 21, 2019 6:03 pm
Codes don't help with a no-start generally, Codes describe detected running faults, not failed parts.
Is this problem solved or did someone check the green box by mistake?
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
Oka
Year and Model: XC70, 2001
Has thanked: 0
Been thanked: 0
Oka
Post by Oka » Thu Nov 21, 2019 10:59 pm
Nope, the problem is not solved.
Oka
Has thanked: 0
Been thanked: 0
Oka
System Tests
Post by Oka » Thu Nov 21, 2019 11:02 pm
At the post that started this thread, way back in September, I did a VIDA test am not sure if I did it right. The audio results were not loud enough for my phone to pick up well (had to digitally increase the volume). Wondering how I can do a better test. Any link of a better VIDA system test?
Oka
Has thanked: 0
Been thanked: 0
Oka
Post by Oka » Fri Nov 22, 2019 8:38 pm
Can the integrity of the Camshaft and Crankshaft Position Sensors be checked with VIDA? If yes, would you know how?
Oka
Has thanked: 0
Been thanked: 0
Oka
Post by Oka » Sat Nov 23, 2019 6:50 pm
Also, it looks like this car does not have a Fuel Pump Relay, right?
Trinidad & Tobago
Re: 2001 XC Car Will Not Start Anymore, intermittent crank, no fire
Post by abscate » Sun Nov 24, 2019 4:14 am
No fuel pump relay on P2s
The ECM and CEM conspire with a small module called thePEM to turn the fuel pump on.
When my PEM went, I had a slight miss at 40 mph or more, then finally,three months later, a crank, no start condition. That would clear and the car would run fine.
Search this forum for pump electronic module or find link in the maintenance thread to by 2005 v70 barents Blue
(Link to maintenance forum in my sig)
