1997 850 N/A: Squeals, Axle OR Hub Assembly
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
This past summer was redoing of passenger axle cv boot, both inner and outer. The boots were GKN. There is no issue except squeal since this service when taking a left turn. FWIW viewtopic.php?f=1&t=29716
To help narrow, I had raised the front on jack stands and ran it at slow speed. Steering left to right, end-to-end, did not generate any squeal. But discovered low steering fluid condition and refilled -- the steering system appears fine.
So, the squeal is only when wheels are under load -- turning left would load right wheel. I'm between axle and hub... suspecting time for wheel hub bearing assembly replacement. The hub assembly is Timken/FAG with close to 60,000 miles on it.
Is it axle related OR hub bearing?
Has thanked: 1610 times
Been thanked: 4065 times
wrrr wrrrrr wrrr wrrrr wrrrrr is wheel bearing and will get louder on turning -
clank clank clank clank is CV joint or spider - and you get that on transition from float to drive, not on turning.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
Most likely not your problem but my coin here just.
I have myself broken strut bearing which makes annoying sound at low speed turning (parking mostly) time to time.. I did myself mistake it first to be some other bearing because as it is.. a bearing which turns of course too. But as sound comes higher than center of wheel it can't be anything else.
