2004 Volvo S60 rear brake hose removal
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Memuns
Year and Model: 2004 s60 2.5T
Post by Memuns »
Can anyone tell me how to replace rear brake hose on a 2004 Volvo S60? There's a bracket in the way of the connection at the brake line and the hose. The front one was easy. Please help. Thanks
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
See this post: viewtopic.php?f=1&t=74744
volvolunut
earthworm
Year and Model: 2003 S60
Post by earthworm »
I have an '03 ..with a ''soft'' pedal ..even after bleeding and bleeding, using gravity and pressure at the master cylinder . .. I cannot remember any bracket, this was last year .. I guess the bracket must go . And, to do that, you may have to disassemble the entire rear brake system ! "Modern" cars were NOT meant to be worked on ! Key word is ''throw-away''......end of rant … IF I owned the Volvo repair manual , I could help ..Well, now we know why the dealer charges $500 to do only this task !
I found the answer , its under ''similar topics'' - with any number of replies . AND, its not as bad, not nearly as bad as I say it is …
Tonyx
Year and Model: 2001 XC70
Has thanked: 3 times
Been thanked: 8 times
Post by Tonyx »
I just did the same on my 03 XC70 rear left caliper + hose. It can be done without taking out the whole assembly per link above with a caveat. What I did:
1. clear all debris from the brake tube nut connection with wire brush and spray with liquid wrench( or you favorite )
2. loosen the bracket where the metal brake tube joins to flex tube by undoing the screw attaching it to front part of wheel well - 10mm ratcheting wrench helpful
3. undo the caliper and bracket from rear knuckle and have it ready to remove from vehicle - 15mm bolts. Have the new caliper with flex hose already attached and ready to go.
4. pack towel under above bracket to catch brake fluid
5. disconnect by turning the 13mm brake tube nut on the metal tube side while holding the flex tube nut steady with 14mm wrench. You have space to turn 1/8 turn at the time by flipping the 13mm wrench back and forth. Patience is needed.
6. don't worry about hurrying as you loose only about 30% of fluid on the brake fluid reservoir working steadily
7. install is reverse of removal :)
2003 XC70 230K and counting..,
earthworm
Post by earthworm »
EXCELLENT response
thank yous are in order …
Working on a Volvo DOES require patience !
Has thanked: 1500 times
Been thanked: 3812 times
I folllowed this exactly and the worst part was picking up the brake fluid and putting it back into the hose.
:lol:
Tonyx
Post by Tonyx »
Well played abscate:) I'll watch how I write next time!
