Did you know? 🤔
Ignition whine in speakers Topic is solved
2001 - 2007 XC-70
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 47 times
United States of America
vtl
Re: Ignition whine in speakers
Post by vtl » Wed Oct 02, 2019 10:31 am
Long ground wire is a source of the ground loop. To be of the same potential both the HU and Yatour would need to have an equally short ground wires connected to the same ground point.
Power in, power out and the ground, yes.
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
Yaworski
Year and Model: 2002 S60
Has thanked: 4 times
Yaworski
Post by Yaworski » Sun Oct 06, 2019 2:29 pm
vtl wrote: ↑
Mon Sep 30, 2019 12:58 pm
Have this one for power: https://www.amazon.com/gp/product/B0049MWUMQ It was DOA, but I was able to swap transistors and capacitor, so it works.
Would I put this in the power line for the Yatour box? The power line for the radio before the tap off to the Yatour? Or the radio power line after the tap?
Yaworski
Yaworski
Post by Yaworski » Sun Oct 06, 2019 2:32 pm
vtl wrote: ↑
The Yatour doesn't have a separate ground wire. I think that it is grounded through the DIN plug.
vtl
vtl
Post by vtl » Mon Oct 07, 2019 5:54 am
Yaworski wrote: ↑
Between HU and Yatour, closer to Yatour.
I think I said that before, but I also had to break off the loop for line-in for my central speaker amp as well. The whine was minor, lot less than through ground, but still.
Yaworski
Yaworski
Post by Yaworski » Thu Oct 10, 2019 10:31 am
vtl wrote: ↑
Another question. Should I ground the filter directly to the car's chassis, the radio's chassis, or through the ground wire for the radio?
vtl
vtl
Post by vtl » Thu Oct 10, 2019 10:52 am
Yaworski wrote: ↑
You do not need to ground it to the chassis.
Yaworski
Yaworski
Post by Yaworski » Thu Oct 10, 2019 1:32 pm
vtl wrote: ↑
Just hook to the radio harness' ground wire?
vtl
vtl
Post by vtl » Thu Oct 10, 2019 9:02 pm
Hook to Yatour's harness. Either splice the cable or make your own male-female adapter. Solder noise suppressor's ground wire to harness' ground wire, cut +12v wire, one end solder to green (input), another to red (output).
Yaworski
Yaworski
Post by Yaworski » Fri Oct 11, 2019 12:11 pm
The Yatour doesn't have a separate ground. I'm guessing that it is grounded though the DIN plug and the the DIN's shell. So solder the ground to the DIN shell?
vtl
vtl
Re: Ignition whine in speakers  Topic is solved
Post by vtl » Fri Oct 11, 2019 1:39 pm
Solder black wire to the GND wire in the cable. The idea is to feed the +12v through the noise suppressor.
These users thanked the author vtl for the post:
Yaworski
