IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy your stuff using this and it helps MVS!
Ignition whine in speakers Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 34 times
United States of America
vtl
Re: Ignition whine in speakers
Post by vtl » Wed Oct 02, 2019 10:31 am
Long ground wire is a source of the ground loop. To be of the same potential both the HU and Yatour would need to have an equally short ground wires connected to the same ground point.
Power in, power out and the ground, yes.
2005 XC70 260k
2016 XC60 40k
Yaworski
Year and Model: 2002 S60
Has thanked: 4 times
Yaworski
Post by Yaworski » Sun Oct 06, 2019 2:29 pm
vtl wrote:
Mon Sep 30, 2019 12:58 pm
Have this one for power: https://www.amazon.com/gp/product/B0049MWUMQ It was DOA, but I was able to swap transistors and capacitor, so it works.
Would I put this in the power line for the Yatour box? The power line for the radio before the tap off to the Yatour? Or the radio power line after the tap?
Yaworski
Yaworski
Post by Yaworski » Sun Oct 06, 2019 2:32 pm
The Yatour doesn't have a separate ground wire. I think that it is grounded through the DIN plug.
vtl
vtl
Post by vtl » Mon Oct 07, 2019 5:54 am
Between HU and Yatour, closer to Yatour.
I think I said that before, but I also had to break off the loop for line-in for my central speaker amp as well. The whine was minor, lot less than through ground, but still.
2005 XC70 260k
2016 XC60 40k
Yaworski
Yaworski
Post by Yaworski » Thu Oct 10, 2019 10:31 am
Another question. Should I ground the filter directly to the car's chassis, the radio's chassis, or through the ground wire for the radio?
vtl
vtl
Post by vtl » Thu Oct 10, 2019 10:52 am
You do not need to ground it to the chassis.
2005 XC70 260k
2016 XC60 40k
Yaworski
Yaworski
Post by Yaworski » Thu Oct 10, 2019 1:32 pm
Just hook to the radio harness' ground wire?
vtl
vtl
Post by vtl » Thu Oct 10, 2019 9:02 pm
Hook to Yatour's harness. Either splice the cable or make your own male-female adapter. Solder noise suppressor's ground wire to harness' ground wire, cut +12v wire, one end solder to green (input), another to red (output).
2005 XC70 260k
2016 XC60 40k
Yaworski
Yaworski
Post by Yaworski » Fri Oct 11, 2019 12:11 pm
The Yatour doesn't have a separate ground. I'm guessing that it is grounded though the DIN plug and the the DIN's shell. So solder the ground to the DIN shell?
vtl
vtl
Re: Ignition whine in speakers  Topic is solved
Post by vtl » Fri Oct 11, 2019 1:39 pm
Solder black wire to the GND wire in the cable. The idea is to feed the +12v through the noise suppressor.
These users thanked the author vtl for the post:
Yaworski
2005 XC70 260k
2016 XC60 40k
