Help with CV Axle Replacement
I am in the middle of changing my drivers side axle on my 2014 xc60 and ran into a snag. The replacement part ended up not fitting, it wouldn't go in all the way because the housing is slightly larger and ends up touching the transmission case. I decided to put the old one back but now it won't go in past the circlip and I can not figure out how to get it past that point. I tried greasing it up and even tapped it with a sledge hammer but nothing seems to move it past the clip. I'm assuming it's the clip that it won't go passed because there is about a 1/4 inch gap between the housing and differential case. What am I missing here?
I think you just have to muscle it back in. Did the clip get bent on the way out?
2015.5 V60 T5 AWD Platinum
2012 XC60 T6
2012 S60 T6
2011 S40 T5
Gone but not forgotten:
2009 C30 R Design Sold to buy more Volvos
2007 S40 2.4 t-boned and totaled
2010 V50 2.4 hit a deer and totaled
2000 V70 SE head gasket
2000 S70 SE sold with 240,000
2012 XC60 T6
2012 S60 T6
2011 S40 T5
It didn't appear to be bent. Your advice is exactly what the service manager at the dealership said. He told me they usually grab the outter end and force it towards the inside end to kind of use it like a slide hammer and it should pop in, but it takes a good bit of force.
- 616 Views
Last post by Blacklab467
- 1310 Views
- 11 Replies
- 3325 Views
Last post by Pretribrapper
- 1574 Views
- 457 Views
Last post by chitownV
