Did you know? 🤔
Vvt Oil leak, block off?
2001 - 2007 XC-70
bufordTjustice
Year and Model: 2004 s60 2.5T
Has thanked: 0
Been thanked: 0
United States of America
bufordTjustice
Post by bufordTjustice » Tue Oct 01, 2019 10:15 pm
Greetings,
I recently picked up a 2004 s60 2.5t at an auction for 900 bucks. I am pretty mechanically inclined, but this is my first Volvo.
When I got the car it had a bad oil leak that was easy to traced to the exhaust cam. Last weekend I spent the time and changed out the timing belt along with both cam seals, thinking the exhaust cam seal was the issue. I was kind of surprised I actually got the timing correct with two vvts, and no CEL. However the leak is still there, if not worse than before.
This leads me to believe that the exhaust vvt hub is the cause of the leak. It also had quite a bit of in and out play. Way more than the intake. Would replacing the large o ring on the vvt hub be worth a shot? I also came across people deleting the vvt hub on various forums. Would it be safe replace the solenoid with one of these block off plates? If understand correctly the plate blocks off the oil passage to the hub. If the car proves to worth the investment, I get a new hub. Looking for a short term solution for the time being.
Blocking plate in question:
https://rover.ebay.com/rover/0/0/0?mpre ... 3429919720
kallekula
Year and Model: S70 2000
Has thanked: 10 times
Been thanked: 7 times
kallekula
Re: Vvt Oil leak, block off?
Post by kallekula » Tue Oct 01, 2019 11:50 pm
Go to the junk yard and pickup a hub without play👍
BMW 540i 2002
S70 Base 2000
S40 T5 2004.5
Has thanked: 246 times
Been thanked: 802 times
Trinidad & Tobago
Post by abscate » Wed Oct 02, 2019 3:55 am
I’m sure it’s goimg to throw a code if it expects VVT and there is no solenoid, so if you need CEL OFF for inspection, that’s a problem
Link To Volvo Glossary
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 46 times
vtl
Post by vtl » Wed Oct 02, 2019 7:00 pm
What's your crankcase pressure?
05 XC70 260k, 16 XC60 40k, 19 Tundra 1k
bufordTjustice
Has thanked: 0
Been thanked: 0
bufordTjustice
Post by bufordTjustice » Wed Oct 02, 2019 9:45 pm
I checked the pressure with the latex glove test. The glove pulled into the oil fill neck both at idle and at 2k rpms showing negative pressure.
Question: will any junkyard vvt exhaust hub that looks identical from a dual vvt hub engine work? Does it matter if it's from a 2.5 or 2.4?
bufordTjustice
Has thanked: 0
Been thanked: 0
bufordTjustice
Post by bufordTjustice » Wed Oct 02, 2019 9:46 pm
No inspections or emissions test in Idaho. Would like to avoid a CEL if I can though
kallekula
kallekula
Post by kallekula » Wed Oct 02, 2019 10:47 pm
Hubs should have part #s that must match what you have now.
BMW 540i 2002
S70 Base 2000
S40 T5 2004.5
Trinidad & Tobago
Post by abscate » Thu Oct 03, 2019 4:50 am
The ECU might also inhibit boost if it can’t adjust VVT to specs, I don’t think eliminating the hub is a good idea
vtl
vtl
Post by vtl » Thu Oct 03, 2019 6:03 am
Transmission in drive, one leg on brakes, one on accelerator. Otherwise there won't be any boost. Revving in P does nothing for boost.
2.5 for 2.5, 2.4 for 2.4
bufordTjustice
Has thanked: 0
Been thanked: 0
bufordTjustice
Post by bufordTjustice » Thu Oct 03, 2019 10:34 am
I appreciate the responses. I will try the glove test again. I probably need to plan on going through and replacing the breather system. The last owner ignored a lot of maintenance.
I will try to located a used vvt hub. It needs to be replaced to do things right. Junkyards are few and far between here, hopefully I'll have some luck.
