Welcome to the world's #1 Volvo forum!
Volvo Fixes & Advice since 2001.
Coolant Leak
diplomaticm3
Year and Model: 2004 xc70
Coolant Leak
Post by diplomaticm3 »
Hi folks, having some trouble with a coolant leak. I thought I’d found the source...after driving, I found some bubbling in the line going from the reservoir to the pipe in the rear of the engine (pictured). I just replaced the line, but the bubbling/leak persists.
Am I missing something here? The engine temp is fine but it keeps leaking coolant after I refill the reservoir.
Thanks in advance for your help.
Has thanked: 512 times
Been thanked: 1525 times
You can try a higher quality clamp on that line, one with a solid clamp area. The cheap ones won't clamp well on a small clamp like that.
xHeart
Year and Model: 2.0/2.4/3.2
Has thanked: 42 times
Been thanked: 67 times
Post by xHeart »
What type of coolant -- is it Volvo? When was the last coolant flush?
Golden Retriever | 2014D VIDA DiCE | 2020 V60CC | 2013A XC90 +150mi/241km | 2001 V70XC +200mi/322km
Past: German Shepherd | 1997 Volvo 854 | 1989 Volvo 740 GL | 1979 Volvo 240
diplomaticm3
Volvo coolant at first...flushed it this month, now using G48.
jreed
Has thanked: 144 times
Post by jreed »
Last year I replaced a similar line on my '97 850, also due to a small leak. There was a crusty build-up of dried coolant residue on the end of the metal fitting. I cleaned it off with an abrasive pad before I put the new line on. No leaks so far.
