Strut bar brace mounts?
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
I recently installed an upper engine torque mount on my '06 V70, old one was really bad.This strut brace bar is new to me. Should I be able to turn the bar a little bit with one hand. Does this mean the left and right mounts are bad if I can. Thanks in advance, Glenn.
DrDan
- Year and Model: 02 V70
- Been thanked: 9 times
Glenn, the bar can be turned a bit with little force, that's perfectly normal. I also found that amount of play suspicious, so I replaced the left and right mounts, but the new ones were just the same
- June
- Has thanked: 523 times
- Been thanked: 261 times
When I had a issue it was a metallic pop from behind the dash. My mechanic knew instantly what it was and tightened the bolts without replacing the mounts. He said those mounts rarely need replacement. My 04 S80 being a P2 car like yours, it's probably the same bar and mounts. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- 910 Views
- 1638 Views
Last post by BackRoadSeeker
- 1413 Views
- 10187 Views
Last post by SuperHerman
- 1359 Views
Last post by darrylrobert
