Did you know? 🤔
Driver Side rear banging noise
Chuck W
Year and Model: 97 854 T5
Has thanked: 10 times
Been thanked: 19 times
United States of America
Chuck W
Re: Driver Side rear banging noise
Post by Chuck W » Mon Oct 07, 2019 1:02 pm
While you're under there, I would take a look at those inner DL bushings anyway.
lcc014
Year and Model: 855, 1995
Has thanked: 0
lcc014
Post by lcc014 » Tue Oct 08, 2019 6:30 am
Thanks for the suggestion. I will take a look.
Has thanked: 212 times
Been thanked: 696 times
Trinidad & Tobago
Post by abscate » Wed Oct 09, 2019 5:25 am
We used to check that we remembered all the kids when we heard noises in the back. They can gon2-3 days easily on leftover goldfish and water.
lcc014
Has thanked: 0
lcc014
Post by lcc014 » Wed Oct 09, 2019 5:28 am
:D
lcc014
Has thanked: 0
lcc014
Post by lcc014 » Sun Oct 13, 2019 3:22 pm
I got all the parts yesterday and started the replacement this morning. It took about 2 hours and 10 minutes from start to "end". The "end" means that all 5 bolts need to be turned to 60 degree, 90 degree and 120 degree. I just torqued them to 65 Nm, and 105 Nm this morning then I had to go to work. I will continue tomorrow morning, Columbus Day to finish it up.
I followed other member in this forum to drill the rubber first before using the tool. I used a 1/4 inch drill bit. Old bushing came out very easy and more time was spent to push the new one in. Tool needed to be straight to push the new bushing in. I also spent a lot of time to remove the old bushing from the chassis pin. I kept pushing the link down to try to get the old bushing out of the chassis pin. I forgot how I did that 8 years ago. So I finally disconnected the shock from the spring and the whole link dropped down effortless ! I should have done that in the first place then it would cut down the total time to less than 2 hours.
I also checked the DL, all were good.
Ching-Ho Cheng
