2006 XC90 2.5T swapped in a used motor which cranked over by hand, put it in car, won't crank over anymore? Help!!
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
Locked
3kgtaddict213
Year and Model: 2006 XC90
Post by 3kgtaddict213 »
I posted a couple months ago about swapping my B5254T2 that I got out of a 2008 s60. My original motor spun a rod bearing after the "no oil pressure: stop immediately" warning.. Got a motor from the junkyard and installed a new water pump, idler pulley, tensioner,
timing belt. Turned the motor by hand like 20 times just to make sure my timing was correct and that it ran smoothly. Timing marks all lined up. Put the transmission back on and put them back into the car. Turned the key and it just clicked, never turned over. My new motor is literally seized. Can't turn it by hand anymore. It'll move counter clockwise but gets stuck at the same spot going clockwise. Pulled the motor back out, removed the transmission (as that was the only thing I could imagine would've changed anything) motor is still seized. I'm beyond lost. This is absolutely insane. What could be going on?! I turned it by hand SOOO many times after the timing belt installation and now it won't go anymore. It never even combusted once when i turned the key so I couldn't have bent any valves.. What the heck happened?!?
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 26 times
Been thanked: 28 times
Re: 2006 XC90 2.5T swapped in a used motor which cranked over by hand, put it in car, won't crank over anymore? Help!!
Post by ndphotonl »
Remove the starter motor and try again to be sure?
Volvo S80 2.4T Wasa Limited Edition
Blog / FlickR / YouTube channel
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 646 times
Been thanked: 272 times
Post by matthew1 »
Let's keep this to one topic viewtopic.php?f=10&t=89845#p519929
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
Locked
