2.3L crankshaft gear puller recommendation?
mp5802
Year and Model: 2001 V70 T5
Has thanked: 1 time
Post by mp5802 »
I'm going to replace crankshaft front seal and camshafts seals soon on my 01 v70 2.3L T5. Can someone recommend a specific brand or generic type puller to remove the crank gear?
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
I just did this job (replaced the crank front seal) recently and used a standard type medium sized 2 jaw puller to pull off the crank timing belt pulley. I do recommend using the special 4 bolt front pulley crank hold tool when loosening and tightening the crank pulley bolt.
One thing you have to be careful of is to keep the crank from spinning while using the puller, especially if you've removed the timing belt, which I don't recommend until later. As I tightened the puller the crank would want to spin so you have hold the puller or use one those special crank hold tools, which I didn't have, that's inserted through a hole in the block. I used a crescent wrench on the puller to keep the crank from spinning. I also left the timing belt on and tensioned as the pulley was being pulled off the crank in case the crank did spin. After the timing belt pulley moves off the crank some you can loosen the tensioner and pull it off the rest of the way.
photos
https://app.box.com/s/b2j8a9243xe0y475c3b8lmo1npih8w2j
mp5802
Has thanked: 1 time
Post by mp5802 »
Thanks for the reply and photos!
Maybe, I'm over-thinking this, but I've looked at the related VIDA repair instructions, and they show a "universal" 2-jaw puller like this to remove the crank gear.
volvo crank gear puller.jpg (37.19 KiB) Viewed 1480 times
I'm seeing similar pullers that I can get, but they come in different sizes for different gear sizes. Typically the sizes are 2", 3", 4", 5", etc. So, does anybody know the approximate diameter of my crank gear?
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
I used this universal puller to get it off my 2.5T. The size can be adjusted.
https://www.amazon.com/gp/product/B0721 ... UTF8&psc=1
mp5802
Has thanked: 1 time
Post by mp5802 »
XC70Rider wrote: 08 Oct 2019, 19:43 I used this universal puller to get it off my 2.5T. The size can be adjusted.
Yes, I figured one of these inexpensive, flat steering-wheel-type pullers would also work. Thanks for the input.
XC70Rider
Post by XC70Rider »
mp5802 wrote: 08 Oct 2019, 19:49
Cottection: The universal puller from amazon is for removing the harmonic balacer pulley.
To remove the ctankshaft gear I rented this puller from autozone
https://m.autozone.com/loan-a-tools/loa ... 8_0_0?aqs=
The gear can only slide back onto the rod in 1 sequence so no markings are needed.
