Did you know? 🤔
2.3L crankshaft gear puller recommendation?
2001 - 2007 XC-70
mp5802
Year and Model: 2001 V70 T5
Has thanked: 1 time
United States of America
mp5802
Post by mp5802 » Mon Oct 07, 2019 1:46 pm
I'm going to replace crankshaft front seal and camshafts seals soon on my 01 v70 2.3L T5. Can someone recommend a specific brand or generic type puller to remove the crank gear?
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 11 times
Been thanked: 9 times
firstv70volvo
Re: 2.3L crankshaft gear puller recommendation?
Post by firstv70volvo » Mon Oct 07, 2019 2:53 pm
I just did this job (replaced the crank front seal) recently and used a standard type medium sized 2 jaw puller to pull off the crank timing belt pulley. I do recommend using the special 4 bolt front pulley crank hold tool when loosening and tightening the crank pulley bolt.
One thing you have to be careful of is to keep the crank from spinning while using the puller, especially if you've removed the timing belt, which I don't recommend until later. As I tightened the puller the crank would want to spin so you have hold the puller or use one those special crank hold tools, which I didn't have, that's inserted through a hole in the block. I used a crescent wrench on the puller to keep the crank from spinning. I also left the timing belt on and tensioned as the pulley was being pulled off the crank in case the crank did spin. After the timing belt pulley moves off the crank some you can loosen the tensioner and pull it off the rest of the way.
photos
https://app.box.com/s/b2j8a9243xe0y475c3b8lmo1npih8w2j
mp5802
Has thanked: 1 time
mp5802
Post by mp5802 » Tue Oct 08, 2019 6:04 pm
Thanks for the reply and photos!
Maybe, I'm over-thinking this, but I've looked at the related VIDA repair instructions, and they show a "universal" 2-jaw puller like this to remove the crank gear.
volvo crank gear puller.jpg (37.19 KiB) Viewed 43 times
I'm seeing similar pullers that I can get, but they come in different sizes for different gear sizes. Typically the sizes are 2", 3", 4", 5", etc. So, does anybody know the approximate diameter of my crank gear?
XC70Rider
Year and Model: 2007 XC70
Has thanked: 20 times
Been thanked: 18 times
XC70Rider
Post by XC70Rider » Tue Oct 08, 2019 7:43 pm
I used this universal puller to get it off my 2.5T. The size can be adjusted.
https://www.amazon.com/gp/product/B0721 ... UTF8&psc=1
mp5802
Has thanked: 1 time
mp5802
Post by mp5802 » Tue Oct 08, 2019 7:49 pm
Yes, I figured one of these inexpensive, flat steering-wheel-type pullers would also work. Thanks for the input.
XC70Rider
XC70Rider
Post by XC70Rider » Tue Oct 08, 2019 10:29 pm
Cottection: The universal puller from amazon is for removing the harmonic balacer pulley.
To remove the ctankshaft gear I rented this puller from autozone
https://m.autozone.com/loan-a-tools/loa ... 8_0_0?aqs=
The gear can only slide back onto the rod in 1 sequence so no markings are needed.
