Did you know? 🤔
'07 S40 2.4i - shifter gets stuck in N Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
VolvoRollo
Year and Model: 2007 S40 2.4i
Has thanked: 2 times
Been thanked: 0
United States of America
VolvoRollo
Post by VolvoRollo » Wed Oct 09, 2019 3:26 am
Automatic transmission gear shifter gets stuck in Neutral. It used to be every now and then ....now nearly everytime. Must use the manual override to get it in gear...error reads gear shifter selector service required ( or something very close- it's my sons car) I changed the shift blind thinking the old one which was broken might be jamming it up ...no luck. Have seen something about a bad "shift selonoid" can cause it. Any ideas? Is this a major repair?....car runs good other than having to use a screwdriver to get it in gear.
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 35 times
Been thanked: 25 times
Peru
theWIFES_S70
Re: '07 S40 2.4i - shifter gets stuck in N  Topic is solved
Post by theWIFES_S70 » Wed Oct 09, 2019 10:22 am
How's your:
https://www.fcpeuro.com/products/volvo- ... 50-8699465
When this thing, made of swiss cheese, is broken you will get shift error messages eventually. You'll notice there's a sensor contact on it. If this is broken, replace it. You only need a bone tool (plastic pry piece) and a lot of patience... It took me over two hours to carefully remove the dash pieces...
You also might need to replace this:
https://www.fcpeuro.com/products/volvo- ... -30759659
Not terribly expensive, considering how much things cost for these cars. (Actually, I'm really surprised this is so cheap!!) I'd imagine this would show up in VIDA though... I'd definitely pull it out and check for resistance.
These users thanked the author theWIFES_S70 for the post:
VolvoRollo
1998 Volvo S70, N/A, 5-speed, 185K
2007 Volvo S40, 2.4i, 5-speed, 99K
VolvoRollo
Been thanked: 0
VolvoRollo
Post by VolvoRollo » Wed Oct 09, 2019 1:22 pm
I appreciate the advice. I replaced the 1st item(shift blind) about two weeks ago. It was broken. Did not help. I'll have to see about part number 2.
Thank you again
VolvoRollo
Been thanked: 0
VolvoRollo
Post by VolvoRollo » Wed Oct 09, 2019 3:31 pm
Dear wifes f70 thank you again. You are spot on. My local Volvo dealer said the 2nd part you suggested was the next step after "shift blind" replacement. It's the circuit board that comes with the (above) gear shifter assembly that is the next likely culprit. I'm with you on the price of the part...surprisingly low cost...I hope it works.. my son is tired of changing gears with a screwdriver and a date in the car..lol
theWIFES_S70
Peru
theWIFES_S70
Post by theWIFES_S70 » Wed Oct 09, 2019 10:24 pm
Well, at least your son is learning how to keep cool and level-headed during a date! :P
Good luck, Rollo! Keep us posted on how it turns out.
I'm lucky I'll never run into this problem! I drive a stick shift! :)
VolvoRollo
Been thanked: 0
VolvoRollo
Post by VolvoRollo » Sun Oct 13, 2019 2:55 pm
It worked...no more sticking in N...thank you again
