hello,
so today I sat down to drive and I can't pull the seatbelt more then half an inch to buckle up.
is this something that could be fixed or does it mean a replacement?
im also looking how to access the panel seatbelt post, how to take off the plastic cover, any info/Manuel data for that ?
2004xc70
seatbelt not pulling out... Topic is solved
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
the panel seatbelt post?
Yeah it looks like you're gonna get a replacement on ebay. taking it out is straightforward, you just gotta look at it and see what needs to be removed piece by piece. And for god sake, unplug your battery before removal.
Mikele82
- Year and Model: XC70 04 + C30 T5 08
- Has thanked: 30 times
- Been thanked: 3 times
Yeah, took it apart and its a non solver without breaking all the mechanics into pieces.
might have a go at it but will probably buy on Ebay. (dealer want 490$ for it)
ill take photos of B column assembly to share for future users and post here soon.
Mikele82
Dealer mentioned I need to access with vida to program the replacement part ?chris11211 wrote: 12 Oct 2019, 00:02 the panel seatbelt post?
why would that be ?
- chris11211
Not something I know. I sometimes get pas airbag off on my rear view (depending on the person). Not sure if it's just a sensor. All I can say is, a working seat belt is better than nothing. Plus, you got a 16 yr old car, one day it'll be better to just get rid of it. So just make sure you disconnect the battery before anything, and get a working seat belt for whoever is sitting.
DrDan
- Year and Model: 02 V70
- Been thanked: 9 times
There's no software in the seatbelt. However, there's a pyrotechnical belt tensioner which is triggered electrically.
There should not be need for programming anything. But do take good care (disconnect battery, wait 5 min), use Loctite and proper torque (Haynes says 48nm, 35 lbf ft), and dispose of the old tensioner safely (explosives).
Note that this is "not a job you should do unless trained and certified to work with explosives" etc.
If you can't unwind the replacement part enough to install, hold it exactly the way it would be oriented if installed. It's orientation sensitive so the belt would hold you when the car's upside down I suppose.
- 2025 Views
- 2007 Views
Last post by joedrt77
- 294 Views
Last post by SakuraSky
- 1499 Views
Last post by vtl
- 1494 Views
Last post by charlesparsons
