Quick PSA about strut spring mounts - '99 V70 XC 31212730, 30714686, 1387860 Topic is solved
wizechatmgr
Has thanked: 24 times
Been thanked: 63 times
Post by wizechatmgr »
If you run into an issue removing them where the strut assembly won't come free because of the sway bar end links, apply a little heat after putting tension on them and then hit it with an impact wrench. Spun the nut right off it without issue.
In my case my struts are shot and I cannot replace them until next year, so I still replaced the spring seat. You may run out of spring compressor here - if you do, make sure to pull the shaft of the strut assembly back out of the strut or you'll never get the seat back on. I learned this in an embarrassing manner...
Also note - if you keep blowing out spring seats, your struts are likely bad.
1999 V70 XC AWD - ~193k miles
Has thanked: 376 times
Been thanked: 1177 times
Re: Quick PSA about strut spring mounts - '99 V70 XC  Topic is solved
I remember painfully grinding that bolt off, I bet that technique would have worked.
Don’t even think of trying to counter hold the link with the small Torx counterhold, your bit will snap like a carrot
My pain was here
viewtopic.php?f=1&t=63370&p=326663#p326663
Link To Volvo Glossary
Re: Quick PSA about strut spring mounts - '99 V70 XC 31212730, 30714686, 1387860
Added part number to title
