2007 S 80 FWD 3.2 -- Upper Torque Rod Replacement Topic is solved
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I've replaced numerous P80 and even P2 torque rods. Have to do it on a 2007 S80. Looks like I'll have to move the coolant overflow tank to get the long mounting bolt out. Anybody ever done it and is moving the coolant tank the trick? If so, anything I have to watch out for in moving the coolant overflow tank? Thanks.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- RickHaleParker
- Been thanked: 977 times
Moving the coolant overflow tank to get to the Upper Torque Rod is by the book. Bolt torque is 110 Nm (81 ft-lb).
Active
Past
Past
- RickHaleParker
IronMike wrote: 29 Feb 2020, 15:29 81 ft/lbs seemed like a lot for these. Can someone please confirm this is the torque for BOTH bolts for the upper torque rod?
Active
Past
Past
- E Showell
Update:. For me this turned out not to be a one person job. When the bolts were removed, the engine rotated, so that I could then not align the mounting holes. I ended up having to take it to my mechanic. Two people needed to do this job.
'95 855 auto (sold)
'95 855 auto (sold)
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
If the engine moved when you removed the torque rod then the motor mount is likely broken and it needs to be replaced
https://www.freel2.com/forum/topic32979.html
Take care
Paul
Take care
Paul
- E Showell
Correction -- Replacing the torque rod wasn't an issue, but during the course of that replacement, I realized that the hydraulic engine mount underneath was shot. When I removed the bolts for the metal cover over that mount, and after replacing the mount, I could not get the upper metal cover bolt holes to line up with those in the hydraulic mount since the engine appeared to have shifted slightly. Thus, it was not a one person job for me and ended up going to my local mechanic to complete.
'95 855 auto (sold)
'95 855 auto (sold)
IronMike
- Year and Model: 2007 S80 3.2
- Has thanked: 5 times
- Been thanked: 6 times
RickHaleParker wrote: 29 Feb 2020, 16:432020-02-29.pngIronMike wrote: 29 Feb 2020, 15:29 81 ft/lbs seemed like a lot for these. Can someone please confirm this is the torque for BOTH bolts for the upper torque rod?
THANK YOU!
- 1770 Views
Last post by dairyqueen814
- 768 Views
Last post by MadeInJapan
- 1307 Views
Last post by Eddystone
- 599 Views
- 1717 Views
Last post by kosh_al
