Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link
Buy your stuff using this and it helps MVS!
Fuel Pump Not Running Topic is solved
- Year and Model: 1995 Volvo 850 Turbo
- Has thanked: 0
- Been thanked: 0
Re: Fuel Pump Not Running
This from 1995 Volvo 850 Review: cartestdrive.com
Standard on the Turbo and a $500 option for the base level 850 and 850 GLT, the side bags join dual front airbags, Volvo’s SIPS (Side Impact Protection System) and new Daytime Running Lights as the most comprehensive passive safety package yet available from any carmaker.
At the top of the line, the Turbo package adds the side-impact airbags, split leather upholstery and electronic climate control.
If you go to Parts Geek search 1995 Fue/Inertial Shut-Off Valve and has for my 850 turbo yrs '92-'96.
- Has thanked: 0
- Been thanked: 0
checked wiring from pin 87 fuel pump relay with jump box 12v and pump runs.
- Year and Model: 99T5 ,99S70,2005V70
- Has thanked: 229 times
- Been thanked: 759 times
Excellent
Now work your way from the relay and check if the 12V isnt getting to the pump because
either
1 The fuel pump relay isnt getting a 12V feed - check upstream for 12V fault
B The fuel pump relay isnt getting triggered to close, or isnt closing.
either
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
- Has thanked: 0
- Been thanked: 0
Waiting to receive a checked out used Main Fuel Relay from Mayflower Volvo. She supposed to call back. This will have the connector attached w long enough wies that I can slice it in for good connection at the relay. My connector is gone and broke a brittle wire. So need get and do this before go any farther.
Going to clean MAF Sensor and EGR Valve w carb cleaner tomorrow. Might as well. Cheap fix. Trying to knock out any and all suggested problems while car is down.
After all this if not start I'll start into Timing Belt...UUHHGG!!
- Has thanked: 0
- Been thanked: 0
Checked on a kit for Fuel Pressure...$120...Nope! Have pressure at back by tank and at injectors where release valves are. Doubt this the problem.
- Year and Model: 850, S/V70, 06 S60R
- Has thanked: 72 times
- Been thanked: 227 times
Don't use carb cleaner on the MAF!!! It will likely ruin the sensor, and be an expensive non-fix.turboman850 wrote: ↑Wed Oct 30, 2019 4:01 pm... Going to clean MAF Sensor and EGR Valve w carb cleaner tomorrow. Might as well. Cheap fix. ...
I post this over and over again on here: there is no point in cleaning the MAF unless (1) it is visibly dirty or (2) you have tested it and it is known to be bad. Otherwise, 99% of the time, cleaning the MAF does nothing more than sell MAF cleaner.
'95 854 T5-R, Motronic 4.4, 185k
'96 855 NA, 140k
'98 S70 NA, 210k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 280k
'06 S60 R, 160k
gone: '96 NA 850 210k, '98 NA V70 182k
'96 855 NA, 140k
'06 S60 R, 160k
turboman850 wrote: ↑Wed Oct 30, 2019 4:01 pmWaiting to receive a checked out used Main Fuel Relay from Mayflower Volvo. She supposed to call back. This will have the connector attached w long enough wies that I can slice it in for good connection at the relay. My connector is gone and broke a brittle wire. So need get and do this before go any farther.
Did you find no 12 V supply at the fuel pump relay?
Don’t skip steps!
- Has thanked: 0
- Been thanked: 0
Ok...now still no pump start. Checking voltages Everywhere!! Well...No readings on pin 86 of FPR to the actuator side for pull down switch side and start fuel pump. Put 12v at Main Fuel Relay w jump in FPR...pump runs fine.
Now checking cont. mod for signal/voltage to the pin 86 from pin 27 of Cont. Mod. there is No Pin in 27 and counted out like 5x. This send volts to close switch to pump. Ooww!! Schematic I been using pins not correlate to print!! And no where in the pins give "ohm" reading to pin 86 of FPR!!! So now in a search of "correct" print and schematic of Cont. Module. You got any help out t fellow Volvo there '95 Volvo 850 Turbo Sportwagon????
Watch your acronyms. FPR is commonly used for fuel pressure regulator , which doesn’t have electrical connections.
Using the wrong electrical diagram is frustrating indeed. It’s even worse when you find out you have the right one, but it has mistakes, got that T-shirt courtesy of VWOA.
I think right now
Your pump runs with 12V at the main relay and the fuel pump relay jumped...conclusion, fuel pump and wiring from main relay to pump is good.
You aren’t getting 12V to the main relay.
I think right now
- Year and Model: 1998
- Has thanked: 7 times
- Been thanked: 2 times
+1 - check all wiring (power AND ground) to and from the main fuel system relay. Ditch the wiring diagram if its giving you that much trouble and manually trace each wire using a continuity test. Check all the connections, especially any pins inside the connectors. You can back probe both sides of a two part connection to make sure the pins inside are making contact. Be sure to use a small piece of wire (or a paperclip) so that you don't disturb the connector.
current - 98 S70 T5 SE (255k km)
previous - 90 745T (400k km - sold); 94 855 T5 - (206k km - blown timing idler bearing)
Electrical problem, poor running/not running
by Faust » Fri Aug 02, 2019 3:21 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 11 Replies
- 118 Views
Last post by Faust
Sat Aug 03, 2019 4:44 am
by Faust » Sat Aug 03, 2019 4:51 am » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 1 Replies
- 52 Views
Last post by 93SCMax
Sat Aug 03, 2019 7:33 am
Fuel pump relay or fuel pump? 99 s70 t5
by speedyt5 » Thu Jun 14, 2018 1:08 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 8 Replies
- 401 Views
Last post by wizechatmgr
Sat Jun 16, 2018 5:08 pm
Acts like it's running out of gas or fuel pump failing
by hiroshima1320 » Sun Mar 19, 2017 7:50 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 5 Replies
- 735 Views
Last post by goldxc70
Tue Mar 28, 2017 2:47 pm
