I'm curious how useful these tools are:
https://www.harborfreight.com/manual-ti ... 69686.html
https://www.harborfreight.com/portable- ... 39741.html
and how static balancing compares to a "professional" job - which I guess would usually be "dynamic balancing"?
I also wonder how dynamic balancing might compare if done by someone who isn't good at it. My recent experience with a commercial tire vendor has me thinking that I may not get what I think I'm paying for and I might not be able to tell the difference.
Likely not worth the effort but does anyone have any experience with or (informed) opinions about manual tire mounting and balancing?
Thanks.
manual tire changer and spin balancer
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
static balancing is better than nothing, but just that.
If you want to make use of the speed the T5 can provide, have them rotation balanced.
a friend of mine had a static balancer way back in his shop, and it was alright, but far from good.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
Find a place that does "Road Force Balancing" and that will take care of just about all possible balancing issues, even one that traditional dynamic balancing may not catch. It is somewhat more expensive than standard balancing, but the computer makes it more or less foolproof. I had it done on one of my cars that had a lot of annoying vibrations, and they completely disappeared. It takes into consideration motions in every axis.enotslim wrote: 17 Oct 2019, 09:42
Thanks.
All U.S. market models.
All running and on the road.
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
When I was young I worked at a tire store. I remember using a balancer that spun the wheel on the car. It was an electric motor that would run a small wheel against the tire tread to spin it. The balancer itself was a round unit clamped to the wheel that looked like a hubcap. It had a shaft protruding from the center with 4 discs of different colors on it. You would touch the individual discs as it spun to stop or slow them and feel the vibration come and go as you played with the discs. I assume they moved small weights around inside the 'hubcap'. It balanced not only the wheel but the entire rotating assembly by telling you where to hang how much weight. We would mark the wheel and one lug stud so it could be clocked properly if the wheel was removed after the balance was done. I have never balanced a wheel better.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- 23 Replies
- 10642 Views
Last post by zupta82
- 1140 Views
- 1585 Views
Last post by darylrobert
- 1493 Views
Last post by zimbodel
- 628 Views
Last post by jonesg
