My wife's 2010 non-turbo has been intermittently showing warning lights and charging system failure messages. Yesterday it happened as I was returning home. I measured the voltage on the battery with the car running and the messages showing. Voltage was 13.8 . Every time this happens, I turn the car off and restart and it goes away. Battery shows 12.7 with car off. No issues starting, battery seems fine. It's also throwing a B1087 code, which is not well-defined.
Has anyone else seen this?
Intermittent Charging System Failure message with B1087 code
dasong
- Year and Model: 2010 XC70
I haven't. But next time the message comes up, I'll check it.
On other forums people seemed to think that the charging was fine, just that the communication between the ECM and the modulator on the alternator was getting messed up.
Yak
- Has thanked: 1 time
Picking back up on a year old thread - I've since replaced the battery during the COVID shutdown, and today I plugged my OBDLink into it and took it for an oil change. On the way back I stopped at Autozone for an air filter. On the 3 mile drive home it lit up with Charging System Failure. The logs show the voltage at the PCM was running 13.6 - 13.8, voltage to the OBD plug was running 13.4 - 13.6. When I shut it off it dropped to 12.8 and 12.4 respectively. So it seems like it IS charging even when I get the failure message. Anyone have thoughts on what I might check next?
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
One possibility is the prem air sensor
For my S80 3.2 I would occasionally get B1087
I recently replaced the radiator (and prem air sensor)
This link has the service bulletin from Volvo
viewtopic.php?f=31&t=87687&start=50
Good luck
Paul
Good luck
Paul
- RickHaleParker
- Been thanked: 978 times
ECM-B108700 LIN Bus "A". General Failure Information. No sub type information
Condition
Engine control module (ECM) communicates continuously with Alternator control module (ACM) and radiator temperature sensor. Communication takes place via the LIN-net. The control module checks that its own signals go out on the LIN-net.
The diagnostic trouble code is stored if the control module detects: Communication is missing.
The control module's test for the diagnostic trouble code (DTC) starts in the event of: Ignition on.
Note! The control module can only detect the fault once the test has been started and the diagnostic trouble code (DTC) is stored when the conditions are met.
Substitute value
None.
Possible source
Malfunction indicator light (MIL), on
Condition
Substitute value
None.
Possible source
- Contact resistance or oxidation on connections
LIN-cable short-circuited to voltage.
LIN-cable short-circuited to ground.
Open circuit on LIN-cable.
Internal fault in another unit in the same part of the LIN network.
Damaged engine control module (ECM).
Active
Past
Past
Yak
Thanks for the replies. I had another user on a different forum suggest the radiator tamper sensor also. Since it's a cheap part, I'll replace that first and see what happens. I was told I might also need to have the software updated.
- RickHaleParker
Something on the LIN network. See above.Yak wrote: 22 Jul 2020, 17:36 Thanks for the replies. I had another user on a different forum suggest the radiator tamper sensor also. Since it's a cheap part, I'll replace that first and see what happens. I was told I might also need to have the software updated.
LIN = Local Interconnect Network.
Active
Past
Past
- 12 Replies
- 11480 Views
Last post by warcraftjunkie
- 2126 Views
Last post by BrickBetty
- 10289 Views
Last post by natural4reelz
- 11297 Views
Last post by precopster
- 3332 Views
Last post by GoLuckydog
