2006 V70 134A Freon Charge Amount
STSCowboy
Year and Model: 2006 V70 2.5T
Post by STSCowboy »
2006 V70 134A AC Charge.
I read in the Volvo Owners Manual the charge is supposed to be 2.2 pounds, I read Motor Specification Guide it’s supposed to be 2.2 pounds. Yet the Placard on the car says 1.54 pounds!
Which is it?
When I bought the car it was undercharged at .44 pounds. The shop serviced it at 2.2 pounds and it worked great for 4 days then it dumped all of the Freon. It’s hooked up at another shop and seems to be holding a vacuum so they are going to charge it to 1.54 pounds and see how the unit performs.
2006 V70 2.5T Geartronic Silver Black Leather 131,000 Miles
STSCowboy
Post by STSCowboy »
Here is an update.
The system held vacuum fine so the AC Shop filled the system with 1.54 pounds of 134A and the system functioned perfectly except a small leak was detected in the condenser. So they evacuated the system and now a search for the best condenser begins as a replacement that is also economically feasible.
STSCowboy
Post by STSCowboy »
AC Update
Found the Condenser to hold a vacuum but leak under pressure. I ordered a new Nissen Condenser from FCPEuro and had it installed. All of the source material told the shop to put 2.2pounds of 134A in as a charge. They did and the system operated fine with a 40* Delta between ambient air and Vent Air but I found a decal by the radiator to charge with only 1.53 pounds. So I took the V70 back this morning and they dumped, vacuumed and refilled the system with 1.53 pounds. Today the ambient temps were 95* in So Cal and the Vent Air was 40* so I had a 55* delta in temps which is insanely great!
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
The Nissens is probably good at $75.
According to FCPEuro, it is made in China.
Valeo is OEM, but it is $200.
Next time do the whole thing yourself and save $.
Autozone etc. rents the vacuum pump for free.
STSCowboy
Post by STSCowboy »
cn90 wrote: 25 Oct 2019, 21:39 The Nissens is probably good at $75.
I have the equipment to do it myself, I have the knowledge and skills to do it myself. I’ve been an ASE Mechanic and an Aircraft Mechanic for 30+ years. Sometimes you just don’t feel like doing it and it’s easier to work double-time at work and sit on your butt than digging into doing the job yourself.
