95 850 GLT Blue Tooth?
viper69
Year and Model: 850GLT 1995
Has thanked: 53 times
Post by viper69 »
My car is all stock, with one exception I have an Alpine 6 CD changer in the trunk I had installed many years ago.
Is there a way to install a Blue Tooth receiver/ device that doesn’t rely on those radio oriented Blue Tooth receivers so that I may listen to streaming music from my phone, be it Spotify etc?
The radio-oriented versions are that good once a radio station interferes with it.
I suspect the CD changer is connected through an Aux-in port behind the head unit.
Is it possible to keep the use of my CD player in some fashion?
Thanks!
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
Stu70
Year and Model: 1998 S70 10v
Has thanked: 16 times
Been thanked: 14 times
Re: 95 850 GLT Blue Tooth?
Post by Stu70 »
I built a ‘splitter’ that shares the audio in lines and switches between the changer and a yatour -via a selector switch in the console arm rest - that plugs into the changer port.
You can only use a Grom or Yatour type device for Bluetooth as the head unit only accepts the audio coming in after it ‘talks’ to the changer and/ or Yatour/Grom via a ‘handshake’ data exchange. I haven’t found any thing commercially available that does the same.
If your handy with a soldering iron and arts n’ crafts it’s all pretty simple
If you want I could draw up some sort of how to?
1998 S70 10v BiFuel “it’s a what??”
Last of three factory fitted CNG Press Cars :roll:
viper69
Post by viper69 »
Stu70 wrote: Sat Oct 19, 2019 3:27 pm I built a ‘splitter’ that shares the audio in lines and switches between the changer and a yatour -via a selector switch in the console arm rest - that plugs into the changer port.
Thanks for responding. I would definitely appreciate a “how to”. I’m a visual learner more so when it comes to cars. If I can’t visualize it, I can’t do it hah.
Curious, do I need to remove the radio/cassette unit?
I didn’t install my CD changer, so any help is good.
Volvo 850 GLT 1995
Stu70
Post by Stu70 »
Oh, your not using the changer?
If your not using your changer then you just need a Grom from IPD or a Yatour from EBay ( use your head unit model (SC-***) when ordering...)
You’d only need my splitter if you wanted both changer and Bluetooth . My splitter box will live behind the radio, so before you start make sure you have radio code. The box simply plugs in between head unit , changer and Yatour. With some wiring to an easily reachable switch. Mines all hidden so looks stock, I’m not a fan of cutting or altering an interior.
gmh
Year and Model: 97 850 R Wagon
Has thanked: 14 times
Been thanked: 15 times
Post by gmh »
Some less pricey alternatives for the aux input and bluetooth adapters are mentioned in this thread:
viewtopic.php?f=1&t=89595
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-present)
2014 XC60 T6 (2017-present)
viper69
Post by viper69 »
Stu70 wrote: Sat Oct 19, 2019 6:08 pm Oh, your not using the changer?
Well I'm not using it currently, but I'd like to. But, I didn't know if I could use blue tooth, AND use the CD player. Or does the CD player need to be removed etc?
I do have the radio code. I'd be super interested in this box of yours.
Volvo 850 GLT 1995
Stu70
Post by Stu70 »
I’ll sit down in the weekend and take some photos with a write up, might make a new post so it’s easier to find in a search. It means you can have the two seperate inputs without retro fitting cables into your factory radio so, retaining the tape player for those Derek and Clive* tapes that never made it to CD.
*Derek and Clive = Dudley Moore and Peter Cooke (Adults Only )
Look it up if that sort of British humour works for you...
Been thanked: 153 times
Post by cn90 »
Bluetooth Info:
Stu70
Post by Stu70 »
OP wants to retain CD changer as well.
The Grom uses that din port on the head unit, so changer is left unusable.
My “box” accepts the Grom/Yatour din plug AND the changer din plug so you can use both, you select which one has priority.
viper69
Post by viper69 »
Stu70 wrote: Mon Nov 04, 2019 9:03 pm OP wants to retain CD changer as well.
Hi Stu
Just wanted to see if you have completed the instruction set with pics for this?
Thanks
Volvo 850 GLT 1995
