Did you know? 🤔
2001 V70XC - Brake line and Caliper Service Topic is solved
2001 - 2007 XC-70
xHeart
Year and Model: 13XC90/01V70X/97N854
Has thanked: 21 times
Been thanked: 42 times
United States of America
xHeart
Re: 2001 V70XC - Brake line and Cliper Service
Post by xHeart » Fri Oct 25, 2019 8:13 am
cn90 wrote:
Wed Oct 23, 2019 2:10 pm
Re brake fluid dripping...
In the BMW X5 I mentioned above, I used a piece of wood to press the brake pedal halfway down. This will stop brake fluid from dripping. Good trick!
Indeed and good trick to know cn90.
Making progress with PB treatment at the junction - day 5. The suggestion to cut off the rubber hose close enough to fit a socket (14mm) sounds reasonable.
Since the passenger's side hex at either connector is deformed a little, as Tonyx points out -- see pix above -- should it be filed a little and straightened for socket to fit firmly?
The driver's side is untouched, so, I'll start with this side.
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +144mi/231km | 2001 V70XC 1st Owner +196mi/ +315km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
xHeart
xHeart
Post by xHeart » Fri Nov 08, 2019 11:16 am
The fluid drip prevention trick is proven -- thank you.
But, surgically removing and bubble flaring looks inevitable now.
Tonyx
Year and Model: 2001 XC70
Has thanked: 3 times
Been thanked: 7 times
Tonyx
Post by Tonyx » Fri Nov 08, 2019 12:05 pm
Sorry to hear that. I don't have any more advice as my brake tubenut loosened without too much issue.
2003 XC70 230K and counting..,
xHeart
xHeart
Post by xHeart » Fri Nov 08, 2019 1:51 pm
Removed using cut off tool. Next step repair parts and tools. HFT for tools. Who may have the flare nut?
Has thanked: 0
Been thanked: 134 times
Post by cn90 » Sat Nov 09, 2019 9:21 am
In the BMW Brake line DIY posted in the first page of this thread, I posted info on line and bolt. The bolt (or nut) is not sold separately. So buy a short line with metric bolts (about $3), cut the end and you have 2 bolts.
Use line with M10 x 1.0 bolt.
xHeart
xHeart
Post by xHeart » Sun Nov 10, 2019 2:00 pm
Helpful!
It took forever to straighten up the hard line. After few practices, this is progress: I'm assuming dirt entered the line will clear during the bleed steps, yes? Or use a syringe to drain and clear before connecting flex hose?
Has thanked: 337 times
Been thanked: 1043 times
Trinidad & Tobago
Post by abscate » Sun Nov 10, 2019 6:32 pm
Push some fluid through the hose before you connect it, you don’t want that dirt in your calipers
Link To Volvo Glossary
Has thanked: 0
Post by cn90 » Sun Nov 10, 2019 8:56 pm
- If you have a stick in the brake pedal (to stop fluid leak), remove the stick.
- Brake Fluid will drip down by gravity., only need a few cc of fluid coming out, then good to reconnect.
- Is that factory Bubble Flare or you redid the Bubble Flare?
xHeart
xHeart
Post by xHeart » Mon Nov 11, 2019 7:33 am
Leaving the brake pedal depressed for now so I can complete the driver's side. Then remove the stick and let both drip a little.
I had to cut off the end and make new bubble flare using NEIKO tool kit -- thumb hurts. Now counting on new ATE flex hose to make a tight seal.
Woking on tube bending skill.
Trinidad & Tobago
Post by abscate » Mon Nov 11, 2019 8:39 am
Just get some pipe/tin/ordinance of the same diameter ( a “form”) as the bend you want to make, and roll the pipe over the form.
Work the bends starting as far from the flare as possible.
Antitank shells are perfect as long as you don’t drop them
Make sure the nut is all the way onto the bubble do it doesn’t get trapped behind a bend!
