xHeart,
Congrats...
The most difficult is always making a correct bubble flare in situ.
As I mentioned above re my 2006 BMW X5, it was challenging to make the bubble flare in situ.
How was the Neiko bubble flare tool?
Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
2001 V70XC - Brake line and Caliper Service Topic is solved
- Has thanked: 0
- Been thanked: 113 times
Re: 2001 V70XC - Brake line and Caliper Service
- Year and Model: 1997 854 NA
- Has thanked: 18 times
- Been thanked: 28 times
Indeed, in situ is ten fold harder. Except for the struts, everything else was removed to make it a workspace -- used glove with grip and dexterity support. Volvo wheel well is huge, you can move in if you're fit.
The choice was between OTC and NEIKO.
I found Volvo's copper brake line wall a bit thicker, real hard to handle and shape barehand, compared to the steel sample I picked up for practice from the neighborhood auto parts store.
NEIKO kit needed lubrication as first step, one butterfly nut's matting surface was uneven and needed flattened.
The yoke to fasten 4.75mm tube gripped the thicker wall real firm. Found the adapter sticking a little afterward, even with careful prep and lubrication.
Two things...
First, the flared-base that sits on the M10x1 nut does not need to be flared-flat to max at the freshly flared line, the flatness is reached during the life-cycle, with each repair providing good seal. Second, a good leak proof connection begins with flared line dripping, and ends with final turn of the nut making a good seal and stopping the drip completely -- live as it happens.
As my friend says, "THAT'S ALL BOYS..."
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +144mi/231km | 2001 V70XC 1st Owner +196mi/ +315km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
- Has thanked: 0
Haha,
This is exactly what I learn from "garagejournal" forum...
These "garagejournal" forum folks taught me when making bubble (or double) flare:
- Stop when the die is about one business card thickness from the yoke, or about 1mm.
So the bubble flare is kind of 98% done. The final torque from the bolt in the car will seat it.
- When installing it, tighten the bolt a bit but leave some room for further tightening. Mine leaked a drop here and there. After further tightening, it is bone-dry.
- And yes, I applied a tiny bit of anti-seize on the bolt threads.
1999 S70 NA Evita right front caliper hot 30648017 (crappy caliper slide bolts)
by abscate » Fri Jun 28, 2019 7:12 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 15 Replies
- 416 Views
Last post by wizechatmgr
Fri Dec 06, 2019 5:54 pm
1999 V70XC Rear brake caliper rebuild kit?
by ForestVolvo » Wed Sep 26, 2018 9:24 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 3 Replies
- 299 Views
Last post by ForestVolvo
Sun Sep 30, 2018 3:07 pm
P80 front brake caliper and hoses question
by scot850 » Sun Apr 23, 2017 2:11 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 2 Replies
- 251 Views
Last post by bmdubya1198
Sun Apr 23, 2017 4:28 pm
98 S70, N/A Car NOT starting after brake caliper replacement?
by theWIFES_S70 » Sun Feb 07, 2016 4:06 pm » in Volvo 850, S70, V70, C70, XC models 1992-2000 - 26 Replies
- 2170 Views
Last post by erikv11
Wed Feb 17, 2016 10:09 pm
