Hello,
I'm researching how to do an upgrade to R brakes on a 2006 2.5T AWD and have one or two questions someone here might be able to help me with... really I just want to make sure I have all the necessary hardware accounted for before I start, so if anyone can back me up and make sure I'm not missing anything, I'd appreciate it. Or if anyone has any tips / recommendations I'd love to hear them too. Also, this might help out anyone else considering the same upgrade:
1. 4x calipers (can't forget those...with spring clips and guide pins)
2. 4x 330mm rotors, pads (probably oem or brembo rotors and akebono pads from forum recommendations)
3. 2x front "impulse limiters" aka steering stop arms (left=30748624, right=30748625) (these appear to be different than those on the 2.5T so I don't think I can reuse mine)
4. Caliper bolts (also different than 2.5T hardware) (front top = 985345, front lower = 985428, rear upper and lower = 985453)
5. 2x Oscillation dampers for the front, (identical for left and right = 9485145)
6. R dust shields (should attach with a single screw which I can reuse off my current shields if I'm correct).
7. 8x rubber bleeder screw caps
8. 8x pad backing plates
References:
Thread:
https://forums.swedespeed.com/showthrea ... viewfull=1
Diagrams:
https://www.volvopartswebstore.com/show ... ct=1186867
https://www.volvopartswebstore.com/show ... evel=24650
Thanks all, rock on.
-Jimmy
R brake upgrade considerations on 2.5T AWD?
- justanotherhumanoid
- Year and Model: 2006 S60
- Has thanked: 7 times
- Been thanked: 17 times
2006 S60 2.5T AWD - Build Log
do88 intercooler, all aluminum radiator, XC90 aux transmission cooler, magnefine ATF filter, Snabb intake elbow & throttle body pipes, custom oval exhaust, rebuilt 16T swap, 17x8" team dynamics pro race 1.2 wheels, ipd sway bars, R brake swap, Hilton tune, sunroof shade that slides open when I step on the gas and closes when I stand on the brakes.
- 1772 Views
Last post by JasonO
- 1069 Views
Last post by benpineapple
- 11 Replies
- 5694 Views
Last post by j-dawg
- 615 Views
Last post by wanderdüne
- 1042 Views
Last post by rguzz
