Did you know? 🤔
XC 90 2008 3.2 overheated / test question
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
stavri
Year and Model: 2008 xc90
Has thanked: 0
Been thanked: 0
stavri
Post by stavri » Tue Oct 22, 2019 4:16 pm
How to I test the fan? It's not coming on. What is the 3 prong female for near the harness connection on the schroud. Looking for how to hot wire to make sure it's the fan before I buy a new one. Has the red, black and small wire to the connector.
Thanks,
Steve
RickHaleParker
Has thanked: 3 times
Been thanked: 484 times
United States of America
RickHaleParker
Re: XC 90 2008 3.2 overheated / test question
Post by RickHaleParker » Tue Oct 22, 2019 7:38 pm
Red, Black and Violet are the inputs to the Fan Control Module (FCM).
Red is supply voltage Positive, Black is supply voltage ground. Check across the Red and Black wires for 12 Volts.
Violet is the control line from the ECM.
It looks like the Violet is a simple current control line. That is the FCM turns of when either a current flows through the Violet wire.
From the wiring diagram, I cannot determination if the FCM is turned on by applying a voltage to, or by grounding the Violet wire. If it was in front of me it would be pretty simple to make a determination. Just monitor the line with a automotive logic probe as the engine warms up. The logic probe would tell if the ECM is applying a voltage, grounding the Violet wire ..... ect.
To check the fan motor there are two wires coming out of the other side of the Fan Control Module that run to the fan motor. Figure out which one is grounded then apply 12V across the two wires to test the fan motor.
4/71 is the FCM.
6/29 is the fan motor.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
SuperHerman
Has thanked: 0
Been thanked: 141 times
SuperHerman
Post by SuperHerman » Tue Oct 22, 2019 9:21 pm
Did you try turning on your A/C? It usually will trigger the fan.
