Did you know? 🤔
Oil seal leaking?
2001 - 2007 XC-70
Rvolvos
Year and Model: 2006 xc70
Has thanked: 31 times
Been thanked: 3 times
United States of America
Rvolvos
Oil seal leaking?
Post by Rvolvos » Tue Oct 22, 2019 5:06 pm
Our xc70 (2006 187 k miles) is leaking oil near the oil pump / crankshaft. Has anyone hands on experience replacing this seal and could this be the source?
See attached picture taken after cleaning the area and driving a bit.
PCV system done & wasn’t blocked.
2006 XC70 2.5T 190k
2006 V70 2.5T 152k
2011 C30 T5 AW55-50SN 99k
2011 C30 T5 M66 66k
Has thanked: 0
Been thanked: 126 times
Re: Oil seal leaking?
Post by cn90 » Tue Oct 22, 2019 5:14 pm
- If no oil on driveway, just monitor it.
- Clean the area and put dye in engine oil to see where it comes from.
- If proven to be main crank seal (unusual before 200K miles), then TB needs to come out, oil pump removed to replace the seal.
Use only Corteco or Volvo Genuine seal. Info of DIY is in forum.
PS: Very often it comes from higher up such as cam seals from the VVT hub area. If so, search for the posts in volvoforum by "jordank".
These users thanked the author cn90 for the post:
Rvolvos
Rvolvos
Rvolvos
Post by Rvolvos » Tue Oct 22, 2019 5:55 pm
Thanks, I was just reading and saw your posts on the 850 platform regarding the crankshaft seal.
Over time is does drip on the street, I managed to solved the leaking angle gear ( seals and O-ring) so one more to do. The car is getting close to 200k, the cam seal are a bit sweating but no large leaks.
I will add some dye and monitor
2006 XC70 2.5T 190k
2006 V70 2.5T 152k
2011 C30 T5 M66 66k
June
Year and Model: 2004 S80 T6
Has thanked: 265 times
Been thanked: 141 times
June
Post by June » Tue Oct 22, 2019 6:52 pm
You may also check the VVT hubs. One of mine sprung a leak around 180K. I noticed several other posts with leaky VVT hubs around 180K. June
These users thanked the author June for the post:
Rvolvos
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
SuperHerman
Has thanked: 0
SuperHerman
Post by SuperHerman » Tue Oct 22, 2019 9:05 pm
Front crank seal or oil pump gasket - most likely the crank seal. The harmonic balancer and crank gear have to come off, but everything above can be left undisturbed. You can lock your cams via zip ties, make sure they don't rotate, and mark your belt with nail polish or white out to get your timing back to original. If you haven't done all the other items (timing belt, water pump, pulleys, ...), now is the time. You say the cams are leaking a bit - tough call as the front ones are a pain to change.
It is not a bad job. I guess, depending on what you want to do with the car long term, it may be worth the few hours and $10-15 to do just the seal. Oil on the belts is not good long term.
These users thanked the author SuperHerman for the post:
Rvolvos
Rvolvos
Rvolvos
Post by Rvolvos » Tue Nov 26, 2019 3:08 pm
Thanks much for the advice.
Short term goal is the become member of the 200k miles club.
I have done a lot of maintenance to it and would like to keep it driving.
Unfortunately my son got rear ended yesterday. Son is okay. Damage to the car appears to be only cosmetic damage to the rear bumper.
He was hit by an old Toyota 4 runner which ended up having a leaky radiator due to the pushed in front bumper. Got to love the Volvo.
2006 XC70 2.5T 190k
2006 V70 2.5T 152k
2011 C30 T5 M66 66k
Rvolvos
Rvolvos
Unfortunately my son got rear ended yesterday. Son is okay. Damage to the car appears to be only cosmetic damage to the rear bumper. He was hit by an old Toyota 4 runner which ended up having a leaky radiator due to the pushed in front bumper. Got to love the Volvo.
2006 XC70 2.5T 190k
2006 V70 2.5T 152k
2011 C30 T5 M66 66k
Has thanked: 0
Post by cn90 » Tue Nov 26, 2019 4:43 pm
Rear Bumper will buff right out...lol...
- Front CAM seals usually leak around 150K.
- Front CRANK seal leaks around 200K+.
I have fixed so many leaking seals in my life that I now develop a new philosophy...if no oil on driveway, I just monitor the leak until it is more severe, then fix it then.
Rvolvos
Has thanked: 286 times
Been thanked: 899 times
Trinidad & Tobago
Post by abscate » Tue Nov 26, 2019 7:07 pm
It’s the automatic high mileage rust protection augmentation feature turning on.
Link To Volvo Glossary
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 26 times
Been thanked: 54 times
MoVolvos
Post by MoVolvos » Tue Nov 26, 2019 7:17 pm
If you plan on monitoring the leak give the ATP AT-205 Re-Seal Stops Leaks a try. Not sure how those seals are made but it could be a stop gap before replacing them.
viewtopic.php?f=11&t=91668&p=522606#p522606
These users thanked the author MoVolvos for the post:
Rvolvos
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
