Did you know? 🤔
oil cap leek
steelfish
Year and Model:
Has thanked: 0
Been thanked: 0
steelfish
oil cap leek
Post by steelfish » Thu Oct 24, 2019 12:55 pm
hello everyone
my 98 s90 has a oil cap leek is it a common problem? thanks
Has thanked: 286 times
Been thanked: 899 times
Trinidad & Tobago
Re: oil cap leek
Post by abscate » Thu Oct 24, 2019 12:57 pm
I think this could be publishable, to find something which will grow in that environment.
Screen Shot 2019-10-24 at 3.00.10 PM.png (476.93 KiB) Viewed 61 times
These users thanked the author abscate for the post:
redc70
Link To Volvo Glossary
bronco
Year and Model: 1998 V70
Has thanked: 2 times
Been thanked: 3 times
United States of America
bronco
Re: oil cap leek
Post by bronco » Thu Oct 24, 2019 1:01 pm
Trinidad & Tobago
Re: oil cap leek
Post by abscate » Thu Oct 24, 2019 1:03 pm
steelfish wrote: ↑
hello everyone
The gasket under the top gets hard, and is a cheap thing to replace every few years.
Part number is
Volvo Oil Filler Cap Gasket - Genuine Volvo 30677936
https://www.fcpeuro.com/products/volvo- ... t-30677936
BlackBart
Has thanked: 68 times
Been thanked: 51 times
Sweden
BlackBart
Re: oil cap leek
Post by BlackBart » Thu Oct 24, 2019 1:21 pm
Just so you don't feel bad about your onion problem, OP, I once pulled off the freeway to clouds of burned oil smoke pouring out the wheelwell. Little did I know, the hard oil cap gasket had failed, oil had filled the valve cover valley, then run down the back of the engine and onto the hot exhaust and turbo housing.
It was Friday afternoon on Memorial Day weekend, in a small town with no dealer, so we filled it up and high-tailed it to a bigger city with a Volvo dealer, pulled into the service desk with 15 minutes 'til 5, and bought the last one they had on the shelf. Vacation saved!
1994 850T wagon
Is it time for a 1964 122 wagon?
Trinidad & Tobago
Re: oil cap leek
Post by abscate » Thu Oct 24, 2019 2:48 pm
Check your leeks for point of origin. Natural leeks fry well in butter, synthetic in oil. Google "synthetic oil leeks" for more info.
bronco
bronco
Re: oil cap leek
Post by bronco » Thu Oct 24, 2019 5:48 pm
You all scared to click my link? :lol:
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 17 times
Been thanked: 21 times
Eddystone
Re: oil cap leek
Post by Eddystone » Fri Oct 25, 2019 10:21 am
steelfish wrote: ↑
hello everyone
The gaskets do get hard and stop sealing. Need to be replaced periodically.
There should ALSO be a slight vacuum at the filler cap hole if your PCV system is working correctly and pulling the oil fumes and other gases into the engine to be burned. If that system gets blocked with crud, you will end up with a positive pressure situation inside your engine that pushes oil past any seals, depending on how bad the situation is.
You can have leakage past an old, hard oil cap seal even if the engine ad fume scavenging system is working properly.
You can do a quick check of that system by pacing a plastic bag or rubber glove over the open filler hole. If the bag is pulled down slightly, you are good (vacuum exists). If it blows the bag away, your oil trap and/or lines are clogged with old dry oil crud and will need to be replace. That job is a pain in the butt, but it is a regular maintenance task.
1998 V70 Non-Turbo/Auto
1993 945 Turbo/Auto
1999 S70 T5 Turbo/Auto
All U.S. market models.
All on the road and running.
PM me if you are near Philadelphia.
BlackBart
Sweden
BlackBart
Re: oil cap leek
Post by BlackBart » Fri Oct 25, 2019 12:23 pm
bronco wrote: ↑
Not EVEN gonna!
1994 850T wagon
amblerman
Year and Model: 1999 s70
Has thanked: 1 time
Been thanked: 27 times
amblerman
Re: oil cap leek
Post by amblerman » Fri Oct 25, 2019 12:58 pm
abscate wrote: ↑
steelfish wrote: ↑
hello everyone
Part number is
WARNING I think that is the wrong part for your s90
The part linked above fits an XC90 but the OP mentioned a 1998 S90
I think the part in question is really
https://www.fcpeuro.com/products/volvo- ... 70-s60-s80
Steelfish, take your cap off, flip it over and look at the type of gasket/rubber washer you have. Is it wide an flat (like my link) or skinny and round (in cross section) like the first link?
if you order a replacement, get a few (they're cheap) and replace once a year.
-A
