Did you know? 🤔
Can a 5 bolt p80 REAR hub fit on the 93 850 4 bolt axle
JimBee
Has thanked: 13 times
Been thanked: 23 times
United States of America
JimBee
Post by JimBee » Fri Oct 25, 2019 8:57 am
My 93 854 is ready for winter driving except that one of the aluminum wheels isn't holding air for very long. It has been ground and resealed several times and air loss is fairly rapid now.
I just happen to have a spare five bolt 850 wheel that's the same style as my 93 wheels and has a mounted tire that's fully inflated after a year in storage and good enough for winter use. So if I can swap on a 5 bolt rear hub a quick trip to Upull and I'm good to go.
Does anyone know if the swap will work?
RickHaleParker
Has thanked: 3 times
Been thanked: 485 times
RickHaleParker
Re: Can a 5 bolt p80 REAR hub fit on the 93 850 4 bolt axle
Post by RickHaleParker » Fri Oct 25, 2019 6:59 pm
The five bolt hub is Volvo Part number 271585. Fitment for 271585 is 1993-1997 850. The 1993 850 GLT has the five bolt hubs.
I cannot say 100% sure the five bolt hub will fit all '93 850s but it looks like a good bet.
Last edited by RickHaleParker on Fri Oct 25, 2019 9:59 pm, edited 5 times in total.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
Platform P2 2004 S60R, B2524T4, AW50/51 AWD, Bosch Motronic 7.0, BorgWarner K24 turbocharger, Plant Ghent Belgium.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 41 times
Been thanked: 137 times
bmdubya1198
Post by bmdubya1198 » Fri Oct 25, 2019 7:59 pm
I don't know if anyone has done this. It's worth a shot, I don't think there are any suspension differences on the '93 aside from the 4 bolt hubs. Worst case, return it or sell it and find another wheel/tire
Also, all US market 1993 models were GLTs, so they are 4 bolt. Unless of course there were some 5 bolt late models, but every '93 I've seen has been a GLT and 4 bolt.
2000 V70R Venetian Red/Charcoal M56 Swapped 195k
2000 S70 GLT Mystic Silver/Taupe 253k
2003 S60 2.4T Silver/Black 112k
2007 XC90 V8 AWD Sport Titanium Grey/Black 166k
1993 944 Base Beige/Beige 221k
1991 944 Turbo Dark Green/Beige 173k
1992 245 Base White/Beige 249k
1998 V70 GLT Black/Beige 199k
1998 S90- Silver/Gray 207k
1995 850 GLT Tropic Green... crushed
2001 S60 2.4T Black/Black 230k
1988 744 Turbo M46 Beige Metallic/Beige 188k
JimBee
JimBee
Post by JimBee » Fri Oct 25, 2019 8:16 pm
I'm pretty sure all the 93's are 4 bolt. The platform does seem the same. I also have 2 96 850 wagons and have used brake parts between them and the 93 interchangeably (many harvested from the junk yard), so I'm thinking the axles are probably the same. I'm kind of kicking myself for not snagging a couple of wheels off a 93 that was at the JY a couple of years ago. They were the same style. Haven't seen another one since, though. I picked up the 5 bolt wheel as a backup for one of the 96's if I need it, haven't had a need yet, though the aluminum rims on both of those do lose a little air over the months, some more than others.
Clemens
Has thanked: 89 times
Been thanked: 45 times
Austria
Clemens
Post by Clemens » Fri Oct 25, 2019 8:48 pm
Other idea: I think there used to be tubes that you could run in tires to fix the initial problem of your leaking rim.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
RickHaleParker
RickHaleParker
Post by RickHaleParker » Fri Oct 25, 2019 10:00 pm
Got the part numbers switched, 271585 is the four bolt, 271795 is the five bolt.
It looks like the question is: Are the spindles the same for both part numbers.
Volvo sold the spindles and the hubs as a set. You might try changing out the hubs. If that does not work out, go back and get the five bolt spindle. Else you could try swapping between one of your '96s and the '93.
Fitment for 271585 (Four bolt).
1993 Volvo 850 GLT 2.4L L5 - Gas
Fitment for 271795 (Five bolt).
1997 Volvo 850 Base, GLT, R, T-5 2.3L L5 - Gas, 2.4L L5 - Gas
1996 Volvo 850 Base, GLT, R, Turbo 2.3L L5 - Gas, 2.4L L5 - Gas
1995 Volvo 850 Base, GLT, T-5R, Turbo 2.3L L5 - Gas, 2.4L L5 - Gas
1994 Volvo 850 Base, GLT, Turbo 2.3L L5 - Gas, 2.4L L5 - Gas
2004 Volvo C70 Base 2.3L L5 - Gas, 2.4L L5 - Gas
2003 Volvo C70 Base 2.3L L5 - Gas, 2.4L L5 - Gas
2002 Volvo C70 Base 2.3L L5 - Gas, 2.4L L5 - Gas
2001 Volvo C70 Base 2.3L L5 - Gas, 2.4L L5 - Gas
2000 Volvo C70 Base 2.3L L5 - Gas, 2.4L L5 - Gas
1999 Volvo C70 Base 2.3L L5 - Gas, 2.4L L5 - Gas
1998 Volvo C70 Base 2.3L L5 - Gas, 2.4L L5 - Gas
2000 Volvo S70 AWD, Base, GLT, GLT SE, T5 2.3L L5 - Gas, 2.4L L5 - Gas
1999 Volvo S70 AWD, Base, GLT, T5 2.3L L5 - Gas, 2.4L L5 - Gas
1998 Volvo S70 Base, GLT, T5 2.3L L5 - Gas, 2.4L L5 - Gas
2000 Volvo V70 Base, GLT, GLT SE, R AWD, T5 2.3L L5 - Gas, 2.4L L5 - Gas
1999 Volvo V70 AWD, Base, GLT, R AWD, T5 2.3L L5 - Gas, 2.4L L5 - Gas
1998 Volvo V70 AWD, Base, GLT, T5 2.3L L5 - Gas, 2.4L L5 - Gas
These users thanked the author RickHaleParker for the post:
JimBee
Richard_TD
Year and Model: 855 2.5 20V 1996
Has thanked: 6 times
Been thanked: 4 times
Great Britain
Richard_TD
Post by Richard_TD » Fri Oct 25, 2019 11:58 pm
I've put a four bolt front hub on my '96 850 when an eBay seller sent the wrong part. Everything fitted perfectly, I didn't even notice it was the wrong part until I tried to put the wheel back on.
These users thanked the author Richard_TD for the post (total 2):
erikv11JimBee
1996 855 GLT 2.5 20V
Has thanked: 287 times
Been thanked: 901 times
Trinidad & Tobago
Post by abscate » Sat Oct 26, 2019 4:21 am
Wait, how do you get the brake over the hub? Or does the rear disc clear the hub?
These users thanked the author abscate for the post:
JimBee
Link To Volvo Glossary
bmdubya1198
bmdubya1198
Post by bmdubya1198 » Sat Oct 26, 2019 8:37 am
It seems you're good to go then... grab a hub and give it a go!
The rotor should go back on, the CB is the same. It'll probably even allow the guide pin to be installed, but the holes won't line up. The wheel will go on too for that matter... only problem will be you can't bolt it on!
These users thanked the author bmdubya1198 for the post:
JimBee
JimBee
JimBee
Post by JimBee » Sat Oct 26, 2019 9:07 am
Helpful points about fitment, giving me food for thought. Abscate's keen observation, shared by bmdubya that the disc will need 5 holes to bolt up the strange wheel. I hadn't thought about that but I do have a few 5 hole rear discs in inventory, even a new one if I decided to splurge and use it, instead of a decent one pulled from a JY donor.
Nod to Clemens, too, for a reminder that there's some sort of sealant you can squirt in through the valve stem to seal from the inside. Worth looking into. And RickHaleParker's discovery that Volvo sells the spindles and hubs as a set is helpful to keep in mind. I've used a hub from a 98 on my 96, was a direct fit, though the 98 hub flange was maybe a 1/4" thicker.
And Richard's pics reminded me of the new 4 bolt front hub I packed in my tool and spare parts kit for a cross country trip a while ago in my 96 855. Fortunately, didn't need it, but it was only when I got back and realized that it was 4 bolt and would have been useless!
