I discovered that the vinyl on my steering wheel has a crack and that crack is right where my hand goes. I want to go to the local u-pull-it and grab a replacement steering wheel.
I don't want to go unprepared with tools so what size socket do I need for the steering wheel?
Thanks.
Steering wheel removal
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
For the 2002 ? It should be easier to unclip it from behind. May find a few tips here www.youtube.com/watch?v=idmPhHNNixI
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
its between 17 to 19mm, maybe 18mm why not take your socket set?...took me ages to figure out how to remove the steering wheel, dont go prying the centre like i did...look for the torque bolts at the back and underneath.
the video posted above is very good. my 2002 has torx bolts not clips
- Has thanked: 1613 times
- Been thanked: 4075 times
Assumption..P2 wheel removal similar to P80
You have to have a key for the car to turn the wheel to access the Torx screws which are in the front of the steering wheel ( remember you look at the back of the steering wheel)
They have to be thin, too, as thefasteners are recessed.
- Been thanked: 504 times
I don't know about the P2 but probably the same as P80.
I wrote the procedure for 1998 S70 clockspring below:
DIY: 1998 Volvo V70 Replacing Clockspring (Airbag/Horn Contact Unit)
viewtopic.php?t=34639
PS: Make sure the battery is d/c'd. Also, wear goggles and keep your head away from the airbag in case it goes off (that 1 in a million chance it goes off)...well, just want to make sure your head remains attached to your body...
- 1258 Views
Last post by WillieEvans
- 3249 Views
Last post by SuperHerman
- 11 Replies
- 1458 Views
Last post by Blacklab467
- 6203 Views
Last post by EngineeringBloke
- 2761 Views
Last post by MoVolvos
