Did you know? 🤔
Need Tire Opinion
2001 - 2007 XC-70
joshdecker
Year and Model: 2002 V70XC
Has thanked: 0
Been thanked: 0
United States of America
joshdecker
Need Tire Opinion
Post by joshdecker » Sat Oct 26, 2019 11:21 am
I was offered some tires by my FIL, but they aren’t exactly the same size I have on here right now. Wondering if this might still work? Not planning to keep the car long...too many things failing/coming apart.
Here’s the info:
2002 V70XC
Recommended tire size: 215/65R16
Being offered: 245/75R16
Mainly concerned about the tires running on the inside of the wheel well.
Not concerned about speedometer/odometer differences. The dashboard is doesn’t work most of the time. When I am done with the car, probably going to a junk yard.
Thanks for the help!
oragex
Year and Model: S60 2003
Has thanked: 94 times
Been thanked: 244 times
Canada
oragex
Re: Need Tire Opinion
Post by oragex » Sat Oct 26, 2019 12:01 pm
The difference in overall diameter is really too much, over 3". I'm not sure it will even fit inside the fender. I would be fine with a difference up to 1" or so https://tiresize.com/comparison/
These users thanked the author oragex for the post:
EngineeringBloke
SuperHerman
Has thanked: 0
Been thanked: 144 times
SuperHerman
Post by SuperHerman » Sat Oct 26, 2019 1:51 pm
Agree - that is way too big.
Sell the offered tires on CL and look for something closer in size. It is AWD so tire wear depth should be as close as possible.
The tire calculator is useful. Just remember the wider the tire the worse it will be in the snow (usually). You can use the other wheel/tire options for your model as reference.
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 31 times
Been thanked: 22 times
EngineeringBloke
Did you see how big these tires are?
Post by EngineeringBloke » Fri Nov 01, 2019 11:32 am
As oregex points out the new tires are bigger. Do check the numbers on the website he provided.
The first number is the tire width in mm: 8.5 and 9.5 in inches.
The second number is the height to width ratio.
The bigger width and increased height ratio indicate a significantly larger tire.
1. The new tires about 1 inch wider and so might not fit on the wheels.
2. Also, and this is not a minor point, they are over 5 inches bigger in diameter (30.5 cf. 25.3 inches)!
If they were to fit in the wheel wells, your turning circle would be reduced to that of a fulled loaded oil tanker! You would have to add a new option to Waze navigation to avoid routes with curves. The tires will hit the side of the wheel well cavity so much sooner due to being half an inch wider of the inside, and 2.6 inches longer from the 'axle' to outside edge (radius).
You may even need a step ladder to get up into your car.
Still, you would get the monster truck look if that's what you like and you don't need to drive your car any more.
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 26 times
Been thanked: 56 times
MoVolvos
Post by MoVolvos » Fri Nov 01, 2019 9:40 pm
That's 3.5" bigger. On the axle the dimension is split in half up and down besides the front and back of the fenderwell space. A monster truck style lift kit? Well, not that drastic but...
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
