DIY: 2004 V70 2.5T Axle and Seal (110K miles)
2001 - 2007 XC-70
Been thanked: 156 times
Post by cn90 »
DIY: 2004 V70 2.5T Volvo Axle and Seals (110K miles)
- This is preventive replacement of CV boots. If you are sending this car far away to your kids in college, then it is a good idea to do this ahead than paying a shop later.
- At 110K, Inner CV boot shows minor cracks but still OK.
- New boots (Inner and Outer) are available at FCPEuro. I used GKN brand, which is OEM.
- Axle Seals: Corteco, search FCPEuro for detail (About $8-$10/each):
---> L side: Volvo 6843112; Corteco 19033885B
---> R side: Volvo 9495018; Corteco 19034067B
- This is advanced level DIY, assuming you already know how to remove the tire, support the car on jack stands properly. I used 2 jack stands on each side (safety first).
- Info on how to support car, removing axle etc. is in forum.
- This DIY will serve as supplement to other DIYs:
1. P80 1998 V70 CV Boot thread (main difference between P80 and P2 cars is the axle bolt):
viewtopic.php?t=29716
2. CV Boot discussion:
viewtopic.php?f=9&t=89775
3. VERY IMPORTANT trick posted by jimmy57:
viewtopic.php?t=62152
PROCEDURE AND MISTAKES LEARNED:
1. You can see I struggle to separate the knuckle from the control arm.
Next time I will loosen the bolts holding the control arm (on the subframe side), as this will allow the control arm to drop down.
2. Minor cracks at INNER CV Boot. NOTE the trick posted by jimmy57 “rotate, tug and pull”.
This trick allows the C-clip open end to point down, allowing the axle to come out.
I also used a cold chisel (wrapped both sides of cold chisel with some cardboard paper) and gently tap the area between Inner CV Joint and Trans Housing, it came right out using jimmy57’s trick.
On installation, I used a bit of grease to prevent rust, which in some cases makes removal very difficult.
3. The struggle using wood b/c I did not loosen the control arm!
5. NOTE the anatomy of a typical seal. Take photos and use your fingernail to feel the EXACT position of the factory seal location w.r.t. to the bore and install EXACTLY like that. In my 1998 S70, I learned it the hard way, I installed the Corteco seal a bit too far in (2 mm further in than factory): it leaked ATF!
- So, for the 2004 V70 2.5T, I forgot which side (R vs L) but the axle seal is about 5 mm from the edge on one side and 13 mm from the edge on the other side. Make note of this. Use a ruler to measure.
- Installation tips: oil the outer lip (where it meets the bore), and use a piece of wood to install it flush with the bore. Now, in order to seat it let’s say 5 mm further, you need to use the Volvo tool but this tool is expensive. I used a PVC coupler (1.5 inch PVC coupler for home plumbing; info in forum), about $2 at Home depot hardware. GENTLY tap the PCV coupler ALL AROUND the edge of the seal. Space is limited and a mistake means new seal! So go VERY SLOW all around, one tap at a time and use fingernail to feel the depth.
- Note the O-ring inside the cup (the cup accepts the axle splines), oil/grease it before inserting the axle.
6. The classic sheet metal screw trick to remove old seal. NOTE that you must drill a hole dead center for the screw.
Do NOT damage either the axle or bore sides!
7. The CV Removal Tool ($17 on ebay) is a must. It makes the job so easy:
8. The OUTER Oetiker Clamp is very stiff, designed for the PLASTIC type OUTER CV Boot.
Unless you are very strong, hand squeeze is not enough.
- They sell a special tool to squeeze it at a specific torque.
- I used the $10 cutter (Husky brand at Home Depot hardware but filed the edges blunt for this job) + hammer to hit the handle for extra squeeze. Or you can use a C-Clamp to squeeze the handle. Once done, you should not be able to rotate the Oetiker clamp (or you can rotate with some stiff resistance): in other words, the Oetiker clamp should not rotate freely.
9. In order to replace the INNER Boot without filing down the dimples (on the INNER Cup itself), I had to remove the round rubber thingy (designed to dampen vibration from the axle, at least in theory!). This was removed using an Angle Grinder: basically a piece of rubber vulcanized to steel, it took 30 minutes to remove this useless thingy. Car runs fine without any vibration whatsoever. In fact, replacement axle now comes without this rubber thingy.
That is all boys/girls, if you have done the Axle and Seal in the older P80 cars (1994-1997 850 or 1998-2000 S70, V70), there is subtle difference but you can do this.
10. The axle bolt, search forum for proper torque. According to abscate, it is
Drive Shaft in Front Wheel Hub (M10)
Step 1 35 Nm
Step 2 Angle Tighten 90°
PS: Bonus: the "Axle Ping Noise", IMHO is created by dry grease in CV Joint, is gone after new grease and CV boots.
Re: DIY: 2004 V70 2.5T Axle and Seal (110K miles)
Post by cn90 »
I am posting this Oetiker Pliers Tool just for fun.
It costs a lot of money, but the purist may like it bc one can squeeze the Oetiker clamp to the correct torque (using a torque wrench).
For now, I am sticking to my $10 Pliers from Home Depot (mentioned above).
Here is the fancy tool...
Rvolvos
Year and Model: 2006 xc70
Has thanked: 37 times
Been thanked: 6 times
Post by Rvolvos »
cn90 wrote: Sun Oct 27, 2019 11:24 am DIY: 2004 V70 2.5T Volvo Axle and Seals (110K miles)
Step 1 35 Nm
Can anyone confirm if the outer joint has an circlip like the 850 drive shaft? I did see the other post and you can see the cutout for this circlip.This one has not a notch.
I am in the middle of this job and it takes a lot of force. Do not want to brake the drive shaft bolt.
2006 V70 152k with ribbed boots.
Thanks
2006 XC70 2.5T 190k
2006 V70 2.5T 152k
2011 C30 T5 AW55-50SN 99k
2011 C30 T5 M66 66k
Rvolvos
Post by Rvolvos »
I stopped using the tool , I was using a breaker bar and ratchet with a long handle and couldn’t pull the outer cv joint off. I filed down the notches of the inner joint and separated the cv axle this way. I was able to remove the inner tripod bearing assembly after removing the cir-clip. That took also a large hammer and chisel.
The GKN inner boot from FCPEURO came with clamps to large of a diameter. I could not clamp them enough to stop rotating. The clamps themselves are different then the clamps from the outer boot. They do not look genuine Oetiker clamps. I had to stop and order genuine Volvo boots for the inner joint.
FCPeuro did check there inventory after sending pictures but all the stock is the same.
First 2 pictures are from the outer boot
2006 XC70 2.5T 190k
2006 V70 2.5T 152k
2011 C30 T5 M66 66k
Post by cn90 »
I replaced the axle seals as above last summer 2019...
At the time, I thought I had RMS leak, a job I dreaded...so I cleaned and wiped the RMS area dry and watch.
One year and 7K miles later, the RMS area is bone-dry.
It just occurred to me that a R axle seal leak can mimic a RMS leak.
I took a random photo from the web just to show everyone that the R axle seal sits above and aft of the RMS area...
