P80 P2 Lower torque rod 30680750 - HUTCHINSON is OEM (10/2019)
Has thanked: 1610 times
Been thanked: 4069 times
User peevarino documented this
by Peevarino » Today, 05:46
Was having a fair amount of CV axle noise when accelerating from a stop, not every time, but most, but only for a second or three. PO had indicated they were replaced and look like it, so I ruled those out, at least temporarily. The upper torque mounts looked fine, and expected those to be relatively new, as well (head gasket repair, and most of the top end bits were replaced). Settled on replacing torque rod and passenger side engine mount before moving on to the hydraulic mounts. Had a few moments between a grocery run and some other weekend tasks, so I put the car up on ramps and got to swapping out the torque rod.
Wow, not only was the rearmost bushing shot, but the play in it had worked the nut off the bolt. No wonder the noise had become so commonplace. Replacement from FCP was the cheap Hutchinson with the usual grinding marks from the Volvo roll mark removal.
Made a big difference, was obviously the problem. Smoother shifting, and quieter ride (ignoring the 22 year old rattles from the dash and spring seats that need swapping out).
Another lesson in checking the cheaper/easier to check parts first.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Hutchinson is OEM on a the hydraulic engine mounts, too.
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
That's good news because the Hutchinson branded one is more than half the price of the Volvo !
I need to replace mine soon as my V70 has similar symptoms and there's little doubts that this is the factory torque rod :?
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Peevarino
Year and Model: 2009 XC70, 97 855R
Has thanked: 28 times
Been thanked: 3 times
Post by Peevarino »
Mine was toast, making noises besides the typical CV creaking.
FCP has them for a little over $20. Which is about how long in minutes it took me to change it out, including putting the car on ramps and getting tools out of the back.
09 XC70 3.2
97 855R
