IPD sale XeMODeX - Experts in Volvo Electronics
Did you know? 🤔
Logged in users can get email notification of topic replies Log in or register (free).
Amazon Link Buy anything with this and it helps MVS!
steering noise 04 xc70
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo's stylish, distinctive "P2" platform cars.
2001 - 2007 V70
2004 - 2007 V70 R
2001 - 2007 XC-70
2001 - 2009 S60
2003 - 2007 S60 R
famfeld
Year and Model: 04 xc70
Has thanked: 3 times
Been thanked: 0
United States of America
famfeld
Post by famfeld » Mon Oct 28, 2019 3:30 pm
Hi,
I have an issue with my steering. There is a noise/cluck and also a looseness effecting driveability. When I'm parked with the car running and turn the wheels, maybe halfway in either direction (doesn't matter), then turn the steering wheel back and forth 10 degrees I hear a clunk coming from the steering/suspension and it feels a bit loose in the actual steering wheel. Also when I'm cornering in the car it feels sloppy (almost like the steering is not totally gradual, rather I can turn one arc or another, but can't get the car to smoothly travel a line on the exit ramp). I've replaced outer/inner tierods, struts, balljoints. I still need to replace right control arm (but not because it's bad, just because its old and I ordered a new one). I was quoted $1100 from a reputable Volvo place to replace the rack, but I'm not totally convinced. Also I was told by a Volvo salvage yard that racks usually only go bad if they are leaking fluid out the boots, which I really didn't know what to make of. At any rate, I need to get under there and really try to figure it out a little more aggressively. Before doing that I was wondering if anyone had any ideas. Maybe the rack is loose??
Thanks,
Ben
chrism
Year and Model: S80 / 2005
Has thanked: 0
Been thanked: 22 times
chrism
Re: steering noise 04 xc70
Post by chrism » Mon Oct 28, 2019 6:27 pm
How about setting the front wheels up on ramps with the steering wheel turned to the “problem zone”, then have an assistant wiggle the steering wheel back and forth while you monitor the entire steering system searching for play? Try with both engine running and not running. Don’t forget the steering column itself as a possible problem.
Year and Model: 99T5 ,99S70,2005V70
Has thanked: 318 times
Been thanked: 982 times
Trinidad & Tobago
Post by abscate » Tue Oct 29, 2019 3:46 am
Ben....do you have a jack and stands! I could have a peek next time I’m out in NoHo.
1999-V70-T5M56 2005-V70-M56 1999-S70 VW T4 BMW
Link To Volvo Glossary
famfeld
Been thanked: 0
famfeld
Post by famfeld » Tue Oct 29, 2019 6:59 am
Thanks for the tips. I'm going to lift the front end and with an assistant look into the whole steering/suspension system. Abscate, lets meet up soon. If your in NoHo, let me know if you still have my number. If not I'll text you. Thanks for the advice.
Feld
