Drive-E 2.0 Whistle
soundquest
- Year and Model: v70 2005
I have the infamous whistle on my 2016 Drive-E... commonly seen on previous iterations of the XC90 and other Volvo platforms. A situation where the crankcase and oil trap components become sufficiently clogged with goo-crust and extended oil change barnacles. So my question is... has anyone run into this issue on this particular engine and done a write-up on the repair procedure? And... do you have a part # for the oil trap? Thanks.
soundquest
Found part number: https://www.amazon.com/dp/B018YNSXDU?ta ... merReviews
Also, wondering if this part can be cleaned and serviced (install a new diaphragm like previous models) or if outright replacement is the only way to go? Anything else advantageous to replace while doing this job?
soundquest
Thanks for the reply -- I should have closed this one out; I will do that now. Volvo released an updated version (which they did not publish -- I had to speak with Volvo dealership parts expert to find this out) which is part number 32242753. Not sure what they modified on this version, but I have it installed and it works flawlessly and quietly. Just make sure you torque down all the bolts to spec or it will trip a CEL.
https://www.fcpeuro.com/products/volvo- ... o-32242753
- 12 Replies
- 5022 Views
Last post by ARMeyer27
- 14 Replies
- 5870 Views
Last post by craywm
- 1276 Views
Last post by oragex
- 2966 Views
Last post by darrylrobert
- 1129 Views
