1999 v70xc no throttle reponse
Volvoeric
Year and Model: 2002 v70xc
Post by Volvoeric »
Have replaced throttle body...and pedal assembly... Still no acceleration...idles great...runs great....???...I'm stumped
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
How can you say it runs great if there is no acceleration ... Something is not adding up with your terminology.
Active
Past
Volvoeric
Post by Volvoeric »
Idles well. Runs smoothly is giving me a waste gate code
Has thanked: 1610 times
Been thanked: 4067 times
Replacing a throttle body without software works20% of the time. Read up on the ETM Forum, below
You probably need to visit Volvo and spend$150 for software. Don’t tell them the throttle body isn’t factory just ask for a software load
Mike Langlois
Year and Model: 2002 V70 & V70 XC
Has thanked: 28 times
Been thanked: 6 times
Post by Mike Langlois »
I had an issue like this on a 2002 2.4T. Tried everything including Vida. Good old fashioned detective work (and 3 months of investigation) lead to the problem. Repairs had been made to the wiring harness just short of the throttle body; crimp connectors instead of soldering. It was inside the harness and really hard to find. Problem persisted and I found a second set of "crimped" wiring repairs just short of the computer module; again buried in the harness. Incorrect wiring color was the clue that led to the solution. They sell new harnesses on e bay and other places.
Volvoeric
Post by Volvoeric »
Interesting...I replaced my etm with a used yellow label unit ... would old fuel possibly effect throttle response...I have know idea how long this car sat...I bought it with a blown head gasket and fixed it
There are two versions of yellow label ETB, one is identical to the white label , the other has a contact less sensor.
I would rule out the ETB as a cause before chasing other avenues
Volvoeric
Post by Volvoeric »
Now I believe I have a stuck waste gate.. .no boost situation....any thoughts...
tyguyc
Year and Model: 2004 xc70
Has thanked: 1 time
Post by tyguyc »
My Thoughts on a open waste gate would be no power or decreased efficiency, not no acceleration.
